2018 T@b 320s towed with 2018 Toyota Highlander with factory tow pkg. The spare is mounted under the t@b and low enough that it scrapes when I back into my driveway. My question is…if I can figure out how to mount the spare to sit across the trailer tongue (in front of custom cargo box) will the angle of the tongue change? Because now, both the tire and the hitch scrape on the drive incline. I dread that portion of any journey.
Thank you for any advice.
0 ·
You'll get more responses posting questions in the Main Topics Sections.
Most folks mount the spare at the front Tongue Jack location.
It is easy to do:
Here is a Forum Discussion Link that has additional links on moving the spare tire
Spare Tire Location
Welcome to the TAB Family.
Adventures: 55 Nights: 376 Towing Miles 46,920
TV 2022 Highlander
What @MuttonChops shows in red (in our case) are a pair of muffler clamps.
Edit - just found that our "donut" car spare tire came from a 2007 Chevy Equinox . Was a direct bolt on to the T@B lug nut spacing , and it fit on the spare tire mount spot without too much trouble if I recall .
2024 NuCamp T@B 400 BD, Grey / White
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
My 320S was a non-boondock, so wheels/tires were 14".
I assume you don't have a foot plate or wheel attached to the jack post when towing/backing up to give more clearance?
I had to back into the driveway at an angle before straightening out to get the 320 into the garage. It was a standard 20' driveway which meant a lot of back and forth to get the trailer into position once I was over the hump. (I was parking on the right side of the garage but backing in from passenger side blind).
Harbor Freight spare tire mount: https://www.harborfreight.com/trailer-spare-tire-carrier-93341.html
Travels with 320-S
Our backing situations are similar, coming in from the passenger and eventually getting to the driver side of the driveway. My neighbors come sit on their porches to watch the show, shaking or nodding their heads as I catch their eye in the side view mirrors.
My dread has been the scraping of the spare tire and jack post as I leave or return in the driveway; it has a significant incline at the apron before the driveway levels. I’m going to try the suggestion of putting some short lengths of 2”x8” boards across the driveway, behind the TV tires, to reduce that pitch. Fingers crossed.
I will check with my auto repair shop about the added 50 lbs of tire on the suspension/tongue weight. And I be sure to hook up and check to make sure all is level.
Thank you for the question and suggestion. Weather here in San Antonio has been great for April, May, and June journeys. (In January, I had a liquid drain down the driver wheel and have been worried about not finding the source and getting stuck on the road. All tanks are holding water and Alde 3020 tank is okay as are hoses I can see so all is good.)
Regarding the weight, the good news is I think the spare is closer to 40# and since it will sit further back than the coupler, it will have even less impact on the hitch weight. To help balance the load, I used to load heavier gear in my 4Runner in front of the back wheel (anything behind the back wheels adds to the hitch weight). I also loaded heavier gear in the Tab directly over the axle, for example, a cooler.
Good luck and happy camping!
