Last Fall I disconnected the battery in my 2024 T@B 400 and left a small light bulb (on an extension cord from my house) under the bed to prevent the battery from freezing. The camper is not on shore power.
Today I reconnected the battery and turned the battery switch on again. The battery has charged up so the solar must be working. However, my phone only shows the Smart Shunt app (which works) but not the app that showed solar charging. The phone only shows one device where it used to show two.
Can anyone help this dummy understand what has happened and what I should do?
Thanks,
Bill
                0 ·
B.
Camper: nuCamp T@B 320S BBC 480W solar and 200ah LiFePO4
TV: JLUR | Tow Package | 100ah LiFePO4 | 200W Solar | DCtoDC
https://revkit.com/donmontalvo/ | https://donmontalvo.com
2024 Kia EV9
Photo of the solar controller, the Nautilus enclosure is behind the camera, pump is below:
2024 Kia EV9
Now I'll go find the fuse and pull it. Then I'll follow pthomas's instructions.
I can confirm that the SmartShunt is displaying the Battleborn battery charge, which is slowly losing power, down to 89% - until I turned the battery switch off.
You all have been so helpful - thank you. I'll keep you posted.
Bill
I didn't try anything as I was soaked kneeling in ice and really didn't want any current coming my way!
2024 Kia EV9
2024 Kia EV9
The app wanted the PIN number and 000000 didn't do it. So I try to put in the PIN on the controller, but the phone only brings up a keypad, not a Qwerty keyboard. Anyone know how to get around that? The PUK requires both letters and numbers.
Bill
Best to all,
Bill
