I recently noticed that I could hand spin the two "bolts" that are part of the bracket that attaches the tongue of my 2021 TAB400 to the body.
The bolts on the other side do not spin. They don't look like normal bolts. Any idea as to how to tighten them? Thx, Mark
2008 Toyota Tacoma
Silver Spring, Maryland
2008 Toyota Tacoma
I'm fairly certain that nuCamp is not directly responsible for this, but can demand more from their suppliers when issues are found.
As far as the huck bolts go, I do make it a point to check all that I can see in my Spring inspection. On our trailer they all have a matching mark on the bolt and the frame so you can tell you if they have rotated with a quick visual inspection. But I generally try to get my hand on them as well. But I can see your disappointment in finding some loose ones. I know I would be upset if I found that. But as the frames come from another manufacturer it is not an issue with NuCamp. I would certainly contact NuCamp and send them photos of what you found. Maybe there was a batch of frames that had an issue or maybe it was just a one off? But anyway I would certainly contact them and get their opinion on the matter. Please let us know how the fix comes out.
Our's was a Covid build in 2020, and while we love our TAB and have put over 15,000 miles on it, we have had numerous problems. We even had to have the factory replace our black tank. We've had numerous leaks, warped cabinetry, and the refrigerator had to be replaced. That said, NuCamp has fixed everything under warranty even after the expiration of the warranty. We do love our TAB, but it is not without its faults.
2008 Toyota Tacoma
With that said, I do have to say Nucamp went above and beyond making what they could right. They sent numerous replacement parts (several pieces of cabinetry which had to be extremely expensive to ship). They even compensated me for my time that I spent fixing things and relied on my honesty of hours spent to reimburse me. I doubt any other manufacturer would've done that.
So it's hard to fault them at least on their corrective measures but yes, the quality control in the RV industry is non-existent. I think most manufacturers take a book from Detroit automakers in the 70s...just get it out the door and we'll fix it when something eventually breaks.
2020 Tacoma TRD Off-Road
I would want this checked out by a technician, preferably a mobile technician to ensure it is safe to tow. We won't be able to provide DIY instructions as we would need to be on site to inspect the unit to be sure.
2008 Toyota Tacoma
2008 Toyota Tacoma
2008 Toyota Tacoma
Totally get the frustration—had a similar experience recently helping a friend inspect a used trailer before purchase. Turned out some frame bolts looked fine visually but were actually loose when tested. We ended up booking a used boat condition inspection through Kiki Marine Surveyor (they do trailers too) just to be sure nothing structural was missed. It gave a lot of peace of mind before moving forward. Definitely worth a professional check if you’re seeing issues like this early on.
