After
years of bumpy trails and long miles on pavement, the brake wire on the
passenger side pulled out of it's crimp connection. I removed the
crimps, soldered the wires, rapped them in electrical tape and encased
the wires in 1/2" Beaded Wire Loom.
Looks a little better and certainly wont pull out again!
You might find a way to pin up the wires around the new connection such that there is NO mechanical stress on your solder joint. Solder *WILL* break over time with lots of vibration (reference marine industry recommendations).
I agree - that may be a problem. First, I tried to find crimp connections, but the metal sleeves in the ones I could find for 10 to 12 Gage wire, were too short for the 3 wires. So I resorted to flux and solider. The wires were inter-locked before soldering and tightly rapped with tape and wire loom. Hopefully, the wires will stay inter-locked if the solder fails. Due to the movement of "pitched axle" there's a twisting movement at this intersection that a bracket wouldn't prevent. Short of removing the bottom cladding and rewiring the entire assembly, I'm stuck with this solution. Any ideas?
Similar issue, though the wire on my 2024 320s had lots of slack, so wore through. I made sure there is enough slack to accommodate torsion axle travel, but not so much to have the same issue happen again.
Used a self tapping screw and 1/4” wire clamp for security, and an extra layer of adhesive heat shrink over the repair. I also caulked the gusseted opening to keep dirt, water, and critters out.
Don Montalvo | Retired Veteran | Full time boondocker Camper: nuCamp T@B 320S BBC | 12V 2x100Ah LiFePO4 | 600W Solar Tow Vehicle: Jeep JLU Rubicon | 12V 100Ah LiFePO4 | 200W Solar https://revkit.com/donmontalvo/ | https://donmontalvo.com
Thanks again, I looked at the flange around the punched holes on my 320 cold rolled frame and realized they were deep enough for for a bracket. Running in this axis, there should be no additional strain on the wires or the connection while securing them. And I've never regretted securing something.
2024 Kia EV9
Yes - looking around is always a good idea
https://a.co/d/0ZcczlO
