Tab 400 Awnings
Does nuCamp have a retractable awning available for the Tab 400 Similar to the Thule found on the LG Max?
2020 Jeep Cherokee Trailhawk Elite
Looking for a TT
  • I just bought carefree awnings and put one on each side of the outside walls, over the windows.  They install like you would on a regular rv, but are sized to fit the tab windows. My next one will be for the front door, but I will make brackets to mount a thule across the front.
    Full-time rving since 2006, tab owner since 2022
  • CheleChele Member Posts: 18
    Hi. I see this is an older post, but I have a follow up question: Did you ever install an awning over the door? If so, how is it installed to allow for the door swing clearance? Thanks!
  • gkreitzburggkreitzburg Member Posts: 61
    I got a moonshade xl -- sets up in 5-10 minutes and stays put in the wind.
    2023 T@B 400 Boondock
  • andytabrvandytabrv Member Posts: 38
    edited May 2025
    I've had good success with a Kingcamp awning of the same style as the Moonshade XL like @gkreitzburg.  I sewed on the keder rail "ribbon" you can buy off of Amazon to let you slide it into the rail and that has actually made it easier to install.  I just slide it into the rail, then put in the support ribs (poles) while it's laying across the side of the camper, then raise it with the the tent poles.
    But, I've been trying to figure out if there's an easier permanent solution. I've seen one person on this forum mount a traditional hard fixed casette type roll-out awning, but it involved a bit of bolting and brackets that looked intimidating.  I noticed that the Canadian Trailer manufacturer ProLite has something that I think is called a "bag awning".  But, for the life of me I can't find it on Dometic's website.  Maybe this is it?  It looks like it's permanently affixed to the top seam of the Prolite camper.  Not sure how that would work on the T@b.
    2022 Nissan Pathfinder
    Cary, North Carolina
  • schattenschatten Member Posts: 24
    Not a retractable awning but saw this idea from another thread. Keder rail parts are available from Amazon.
    2023 Tab 400 Boondock
    2024 Chevy Silverado 3.0 Duramax
