Dutchman Window Repair
clkeller
Member Posts: 46
It's hard to explain but my window popped out of the window frame. I pushed it back into place no problem should I use glue or calking to hold it there. I am sure all that happened is the glue let go. Not a leaky window.
Weird - What year is your T@B? Which window?
It's a 2010 Dutchman side window
Yes it is any idea
I guess if it was me, I'd call the factory (contact info over in right column) and see what they say, they'd know. Maybe send them a pic once you've made contact. Or I'd stop by an autobody or auto glass shop and see what they'd recommend.
Thank you
I agree with PXLated. If you call Elsie at Pleasant Valley RV, she will straighten you out. I bought a front window from her for my 2007 DM T@B and when I took it and the T@B to the auto glass place that I respect, the owner called me later and said it couldn't be done without an added metal frame. I called Elsie and she offered to call him and explain how it was done. Later on, I called over there and they still said they couldn't do it, and I said fine, I'll come pick up the trailer and take it to a Little Guy dealer for the installation. When I arrived to pick up the trailer and pay him for his time, his wife announced that he somehow figured out how to do it. He never admitted that Else set him straight. But I know that's exactly what happened. She is great.
Katt and Miss Cannoli the Zen Dog
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny" -
Do you have a phone number for them I live in Canada
Contact info link is over there in the right column...Talk to Elsie...
http://tab-rv.vanillaforums.com/discussion/204/t-b-contact-numbers-info#latest
Thanks so much
Nomad, the link to talk with Elsie is not working. I have an 07 DM T@B and the latches to close/lock windows broke. Need to find out how to replace and or order new window
@CnAFergson - Nomad is no longer on the forum. The process to obtain parts has changed. You need to contact a dealer for parts. On vintage TaBs, you may have to source parts on your own.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
