22 TAB 320 CS-S 3 way Fridge
Has anybody tried installing a 3 way Fridge on the 320 CS-S in the rear? Was there easy access to the propane line? How did it perform? What model did you use? Size etc. Thanks.
  • MarcelineMarceline Member Posts: 1,743
    My understanding is that it’s impossible to properly vent a propane fridge in a clamshell. Why do you want to do this? What’s the problem you’re trying to solve?
  • DaveSDaveS Member Posts: 9
    Well it seems propane is less draw on the batteries, We have a 22 320 CS-S Boondock but no Lithium (Yet) Until I get it better set up to run longer on a 12 volts. I do have Bluetti 200 watt solar panels but for some reason I don't see an external plug to plug the panel in. We almost never go to campgrounds so I need to keep an eye on the batteries. The fridge that comes in the clamshell is almost a laugh for how much it will hold. We do have a 12V ARB 72 qt fridge that we keep in the Jeep with a Bluetti power station.
    Especially since you already have a very efficient ARB cooler, do the lithium upgrade instead of the propane/3 way route.  No regrets.  You can hook up an external 12 V port to plug in the ARB.  Is it a Norcold or newer 12 V frig in the galley?
    You are right about a 3-way on propane when boondocking not drawing much from the batteries. But fortunately, a lithium upgrade is much cheaper then it used to be. And that upgrade would be much cheaper then rebuilding a CS for a 3-way. You can connect solar cells directly to your battery (s)
    California, USA
    Buying 100aH lithium battery would be much, much cheaper than buying and retrofitting a 3way fridge, if it was possible to safely install a 3way (I'm pretty sure that it's not). You can also add a controller for your 200w solar panel.
    But if you already have a 72qt ARB + a Bluetti power station + 200w Bluetti panel I would just use the ARB for keeping food cool and skip the T@B fridge altogether.
