Hello everyone! I’ve been asking a lot of questions lately and I very much appreciate your collective responses. My name is John. Last fall on a trip I found I did not have any battery power, so I’m getting ready for a trip this summer and I’m trying to sort everything out so I don’t have that issue again, doing some upgrades, etc…
I’m just going over the camper, testing everything out, and here’s a thing I didn’t expect - when I pulled my 320 into my garage, I found that the solar panel is still putting out about 6.13v. I assume this means my garage LEDs are activating the panel, and though not a lot, I’m getting steady voltage. With garage lights off it drops to zero. Can someone confirm this is as expected?
I have two sets of wires connected to the battery. One is coming from the solar panel and the other is connected to the 120v converter, is that correct?
When the camper is connected to house current, the 120v converter is putting out 13.83v. I assume that sounds about right?
So the battery is not in use when connected to house current - it’s just getting charged, correct? And when not connected to house current, the battery is supplying the energy to run stuff, and the solar panel is charging the battery, correct?
Thank you for helping me understand this. A wiring diagram would help here but I don’t see that anywhere in the supplied literature.
John
Year of your 320 would help. Also, how are your measuring the voltage?
