Alrighty, asking this group for any advice because I think I’ve read enough forums and I’m not really getting anywhere
Happy 4th! Hope everyone enjoyed it!
Here’s a bit of a timeline and I’ll put a TLDR at the bottom. We have a new 2025 Tab 360
We drove out to the Sawtooths on Thursday morning last week, set up camp, didn’t really feel the need to check out battery life on our camper bc the solar usually does wonders on drives so we figured it was full. The voltage also read 13V.
Woke up Friday am at 4:00 to the fridge blinking night mode assuming the battery was getting low, we turned down the fridge and at 5 am the Tab powered off completely - at that point I looked and our voltage was at 10.7 (didn’t check the state of charge). A bit caught off guard bc we’ve never had this happen as the solar keeps us pretty full. This trip we only had the fridge running over night, other trips we’ve had the heat, fridge, and charging ports used and no issues so this was concerning.
*we did have a torrential downpour for a few hours from 4 am - 9 am - weather impact?
…Plugged the camper into the generator to give it a boost and unplugged it to see if it was still holding a charge (this Is before I learned how to read the victron app for state of charge) and it was powering stuff just fine. Almost like it needed a jump start? Went to Check the Victron app again and I’m now only seeing the Smartshunt and no solar. Waited a bit bc it was a gloomy day. Ended up plugging the camper into the generator to get it to 95% SOC and turned it off.
Saturday- battery was fine all Friday night-sat. We left for a 7 hour hike, figured we’d let the solar charge for the day to see if it’s working. We got back and the SOC had decreased so we knew it wasn’t working (usually the solar would keep the life at ~90%, with our fridge on, it was at ~77%) and again our voltage was low at 10.7. We checked the fuses on the battery, #6 “The power converter and heating pads” was blinking red so we unplugged and plugged it back in (is that bad?) and the blinking red stopped but maybe that has something to do with the solar? We looked under the bed at the smartshunt and unplugged a fuse and plugged it back in and for a split second it showed up on Victron but went away.
….I’m rambling..
TLDR To my point now, I’m still not seeing the solar on the victron app, I’m wondering why our battery did die overnight (was it not actually charging during our drive) and how would I check to see if the solar is working or not. And maybe what the blinking red was for the power convertor, heating pad fuse. Is there a connection feom battery to the solar that I should look at?
PS. I’ve done everything from uninstalling the app, I’m the only one that has it connected, I forgot the device and added it again.. pretty much everything.
Edit to add: we’re driving home and our battery life keeps decreasing so I think it’s confirmed the solar isn’t working so what should we look for? Also the battery voltage is showing 13.31, should this be lower if the battery life is like 40%?
- 270Ah 12-volt Lithium Battery Bank with Internal Heat
- 3,000-watt MultiPlus Inverter/Charger
I’m finding this thread quite insightful - https://tab-rv.vanillacommunity.com/discussion/19413/lithium-charging-question-newbie-solved/p1Our wires are set up exactly as the posters were and Nucamp confirmed that there’s were incorrectly wired thus giving a false reading in the victron app. It doesn’t really solve the fact the solar disappeared from our app (and is now impossible to pair again) and how our battery drained so quickly over night but it’s a start I guess!
I linked a thread in my other response stating that possibly the wires at the solar controller are not hooked up properly, I’m wondering if that would solve the whole SOC vs Voltage issue?
Battery monitor is resetting to 100% and giving you a false reading on your SOC. This would happen if you ran the battery all of the way down and it got enough charge to reset. Verify this by:
In the VictronConnect App, access your BMS, or SmartShunt (same device.)
If it does, I recommend changing that setting to "Clear", which will force th eBMS to wait until it gets a proper reading to give you a SOC.
The second thing I am wondering if the Multiplus (inverter) is in the "On" mode versus the "Charge Only" mode?
https://youtube.com/shorts/uLrBArL090w
