Hitch drop distance
Explorers2Explorers2 Member Posts: 41
Hello. In figuring out my preferred ball position, how do I want the trailer to ride? If level, the drop from my ‘22 Outback Wilderness hitch looks like it’s going to have to be 4-5 inches. What do folks think?
  • AnOldURAnOldUR Member Posts: 1,636
    edited July 9
    Level to a little nose down for safe towing. Don’t forget to take the back of your tow vehicle sagging into account. If it’s much more than an inch, airbags or a weight distribution hitch may be needed. Airbags will be enough to level the ride if the squat is not too bad, but for anything over two inches I’d consider the WDH.
  • Explorers2Explorers2 Member Posts: 41
    For WDH you’re talking about the amount of vehicle squat when I load the hitch w trailer weight, correct?
  • HoriganHorigan Member Posts: 810
    Yes.  The concern is blinding folks with elevated headlights and reduced load on the front axle that may reduce controllability.
    Rich
    2019 T@b 400
    Bellingham WA
