My passenger taillight on 2020 320SBD has had a variable number and location of lights that worked. When only the three bottom ones worked yesterday, I tried to rewire it. The connection to the white wire was probably the problem because it separated from its connector as I wrestled the wires out of the hole which I had to enlarge. The other end of that wire is inside the trailer.
Any suggestions on how I can access it to retrieve it?
TV 2022 Highlander
Nothing more frustrating when doing a project than to see the wire disappear
Know @psytab will resolve . . . . but since I've been there more than once . . .
Now that I’m working in that area again, I see I didn’t need to cut and lift that white sheet. When I pulled on some wires, I recognized them from pulling them the other way😂
1) If you have access to all the taillight wires at the rear tailight and they are all in working condition as mine were, I should have just cut the non working taillight wires at the rear of the taillight leaving plenty of wire to splice the new taillight into. If I had done that I would not have had to renovate the back shelf, job done.
2) Since I was not thinking clearly and did not do 1 I made an easy task much harder than it needed to be by removing the rear cabined, moving the white sheet, and undoing the taillight connections at the blue splice connector in my picture. This resulted in another problem for me and that was when I connected the blue splice connector I did not completely splice into the wire which resulted in two days of troubleshooting until I went back and firmly squeezed the connection completing the circuit.
TV 2022 Highlander
