In my 2019 T@B400 (no solar) I just replaced the two original AGM Harris Batteries with a single Battle Born 100ah lithium. The original charger, 55 amp WFCO 8955PEC, isn't lithium compatible. Battle Born Rep offered a 55 amp Progressive Dynamics 4655V to convert the WFCO to Lithium capable. My problem was the factory wire between the WFCO and the AGMs is 8 gauge and runs 22 feet long behind cabinets and under the bathroom floor. Both Battle Born and nuCamp agreed that is undersized for that distance for a 55 amp charger. I don't know why it also isn't undersized for the existing AGM batteries. Though I know of no problem it caused in the 4 1/2 years I have lives in my T@B. Instead of running 22 feet of 4 gauge wire I bought a PD9345 "deck mounted" charger, installing it right next to the new lithium battery. Only 2 feet of cable required. Also I disabled the charging feature on the WFCO by removing a single power wire for the panel breaker. FYI, I also installed a shunt to monitor the lithium battery and an ANL fuse on the battery's hot wire. Progressive Dynamics said to run a dedicated ground wire from battery-negative to chassis-ground. The existing battery compartment vent hole provided a passage through the floor. Since Lithium doesn't require venting for gas I eliminated the battery encasement cover.
2017 Highlander Limited
Southern California
Full-timer since 2019
Southern California
A few questions:
How come you used the PD 9345 instead of the PD 9360? Wouldn’t the 9360 charge the battery faster?
It looks like you put in an AC outlet to power the converter. Did you create a dedicated circuit for the outlet by running the outlet cable back to the power center and installing another circuit breaker? What gauge cable did you use?
Did you keep the OEM inverter?
Thanks!
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
I have 3 Renogy 100ah Lithium batteries in that space now. While I too have concerns about that wire being undersized, it doesn't seem to be an issue so far. I have felt the charge wire while charging at 55 amps and it hasn't been hot at all. I plan to install a larger gauge wire in the spring, but not sure where the 22 ft measurement is from/to.
Poughquag, NY
Southern California
Southern California
LiTime 12V 230Ah Plus Deep Cycle LiFePO4 Battery with Low-Temp Protection. This single 12 V is small enough to fit the space of the Harris AGMS with a little to spare. I was just worried how to get them out and the idea of going out the cargo door is great.
I also have no solar on board and no inverter, just a solar charging port on the driver side and a shunt next to the distribution box. I was wondering about the need to remove the passenger third of the bed platform. Did you remove the hinges to do that?
And did your require more cables for your new battery?
Thanks
My cover looks like this:
Southern California
The battery cover on the Harris batteries was keeping me from starting but when I did, I only found 4 screws securing the top of the cover, and I only had to remove one bed panel along the passenger wall to get access.
The LiTime 230 amp hour with low temp protection was a slightly smaller footprint, and allowed room for the small 10 am Lithium charger on the cargo door side.
As you mentioned, the cover was able to angle back and then tilt to the middle of the trailer to get access to the battery posts. The existing wires (White is Neg and Red is Pos) were plenty long enough and basically required no wiring changes at all. Just hooked up the lithium and done. I had an inexpensive shunt that turned on and I reset to the new 230 amp hour level and it all worked!
Now as I understand the original WFCO converter will not bring the lithium to 100%, I used the space next to the cargo door for the new small charger, which in my model can plug into the AC plug (for the frig) that is on the wall just inside the cargo door. It is a 20 amp circuit so I can just swap plugs when I need to top off the battery or can use a splitter. Again, no rewiring so very relieved on that count.
Hope these pictures can help others as needed, though our 400 is now over 5 years old and likely does not resemble the build of the new units.
Thanks again to all on the forum
Southern California
Since we rarely boondock, like you, I felt my need for a charger for the lithium would be infrequent. And I had the small frig which has a 20 amp AC plug right inside the cargo door I use for the new charger. I think I can rely on the small charger to keep my battery topped off from time to time, but I am worried about leaving the WFCO non lithium connected all the time. What did you do?
Southern California
Not sure if this is helpful of a typical connection. The AC power is on the left and the DC wires are on right.
The white and black wires will disconnect AC from the converter. Black is connected to a breaker.
Southern Maryland
I pulled both the White and Red with all power off, thinking these only went to the battery. Turned shore power on and none of the 12 V circuits worked. Same with pulling only Red or only White. So not sure where I messed up.
12V DC WIRING: Only the red wire in position 001 goes to the battery. The second red wire (002) is reserved for a higher load 30-amp max branch DC circuit. (WARNING: do not use 002 for connection to the battery.) The black wires (003-007) are for 20-amp max branch DC circuits.
Your DC items go to the individual numbered wires, corresponding to fuses. (+ side.)
Your return side (white neutral wire) of DC items go to a ground bar outside of the [PD4135], which in turn are connected to the DC-side of the system and battery. Or, sometimes, the chassis is the DC return and the lights, etc. are connected through the chassis.
The black wires (marked 003-007) and corresponding fuse slots (F3 - F7) are for 20-amp max branch DC circuits.
The red wires and corresponding fuse positions are rated for 30 amps max - marked 001 and 002.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
