Hello all,
Many posts on this forum seem to suggest that the Nautilus port can be used to power something in addition to being an input for a solar panel/charge controller.
I have a 2025 Tab320S and that doesn't seem to be the case. The port appears unpowered or is floating at about 14 mV. The black wire seems to head to the ground bus bar under the driver side bench. The red wire is heading back into the ALDE area. I have not traced it fully yet but is may be heading towards the batteries. Does anybody know what the deal is?
My goal is to power my Starlink mobile off this port if possible so I don't have to run a wire through window or the door.
Thanks in advance.
2025 Tab320S pulled by Ford Maverick
0 ·
https://www.etsy.com/listing/1819102093/starlink-mini-dc-cable-panel-pass
Then install a step up converter (12 to 30V 3.5 AMP) on the inside of the camper so you can power the Starlink Mini directly off your LiFePO4 battery.
Lastly would install an on/off switch between the converter and the LiFePO4, so you can power off the converter when it's not being used.
Lots of ways to skin this cat...
https://revkit.com/donmontalvo/ | https://donmontalvo.com
The SAE port in the Nautilus compartment of my 2024 320S accepts standard SAE cables.
I plan to replace it with an Anderson Mini port since my stuff uses that kind of connector.
My post provided a way to hard wire for efficiency and reliability, assuming you want to dedicate the port to Starlink Mini. Lots of ways to skin the cat though.
