The foil tape that seals a seam behind the outside grille is cracked most of the way around the cabinet. Should I remove the grille, replace the tape and re-caulk the grille? Is the metal tape really critical? Photos attached
Same thing happened to mine and last year I had the dealer do just as you said: remove grill, retape with foil, replace and seal. It's been a year and it's still good.
Debbie in Oregon Sold 2023 Tab 400 Sold 2018 T@B 320S
Sold 2023 Tab 400
Sold 2018 T@B 320S
