Norcold Fridge constantly running
The Norcold 2-way fridge in my 2019 Tab 400 Boondock is set to zero but constantly runs.  I cannot get it to turn off completely so is this normal?  Any information or experience would be much appreciated.
  • MuttonChopsMuttonChops Member Posts: 1,805
    edited August 14
    Disclaimer:  No direct 2-Way Fridge experience.
    A yr-2019 TAB 400 most likely has the Norcold NR-740 series Fridge.
    nüCamp installed these to operate on 12VDC only, when on Shore Power the WFCO Power Center not the battery powers the Fridge
    { not valid for yr-2019, occurred during a later production year. }
    NR-740 User Manual states when the Thermostat is set to " Off " the Fridge is off.
    Assuming your reference to " Zero " means the Thermostat is at it's lowest setting (off)
    then it seems your Thermostat has failed ( a common failure BTW )
    Replacements are available for around $35 on the web.
    Do confirm your Fridge Model Number before ordering.
    Until a replacement is installed. . . .
    Your trailer may have a 12VDC Power to Fridge toggle switch,
    turning it off will stop the Fridge operation.
    If not on most rigs the DC Fuse panel position #9 feeds the Fridge remove it to turn-off.
       Check to see if your Power Center has a list of DC Fuse Circuits to confirm Fuse # to remove.
  • drackusdrackus Member Posts: 5
    I also have a 2019 Tab 400 with the Norcold fridge.  It was not running consistently.  I installed a new thermostat and it works perfectly now.
    I ordered the replacement from the RV Fridge Guys. https://rvfridgeguys.com/
    Norcold Thermostat Control Assembly 635832 (NR740/ NR751)
    635832
    By the way, my 2 way fridge is wired into both the 12v system and the 120v system.
    The exact Month/Year nüCamp switched to only wiring the 12V side is unclear.
    Most owner remarks suggest it may have occurred before year-2022 when it appeared in the updated Owners Manual.
    I'll edit my earlier post in this thread.
