Hello, 2023 T@B 400 owner. I think the tension needs to be adjusted on the portal window shade, but I access the the window frame to make any adjustments. Has anyone else ran into this and were you able to fix it? Thanks!
Try pressing gently but firmly on the frame around the shade. The cover is held by very slight friction. It will open while driving but doesn’t need much friction to hold it closed while parked.
2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x42016 Toyota Tundra 1794 4x4 John, Northern California
