Has anyone changed the spare tire from a 205 to a bigger tire? Like 225 or 235? Did it fit in the space still? I will probably replace the running tires before next season and if I can change the spare to a full size that would be a big plus.
I plan to move a tire from the axle to the spare when I get the next set of tires. I change my tires before they're worn out or age out so that tire will still have tread. If you put a new tire on your spare and don't need it you'll be throwing away that tire in 6 or 7 years when it ages out. In the early days, pre-T@B, I lost tires due to age. Then I learned that tires have a life span regardless of wear. BTW, since I live in my T@B and travel a lot I wear tires out before they age out.
2019 T@B400 TV: 2017 Nissan Frontier SV 4X4 Southern California Full-timer since 2019
South Jersey
Southern California
