What air pressure do you use for the T@b tires?
vito
Member Posts: 181
I just realized that since I got my new T@b about 8 weeks ago, I have not checked the pressure in the tires since they look and ride fine. I was wondering what the recommended pressure is for the T@b.
2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois
2011 Subaru Outback
Rockford, Illinois
vito, if you will do a search for "tire pressure" from the upper right, you will find numerous discussions on this topic. It is a subject with many various opinions, but this search will let you see what many people consider the "right" pressure for different situations. I personally run 45 psi in mine.
Thanks for the reminder, I need to check mine.
I run ours at 45psi too.2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota -
Funny, I was just reading in the Little Guy's owner's manual that they recommend T@B tires be inflated to 35 psi regardless of the recommendation on the tire. Seems pretty low--does anyone here run at 35psi?
Doug
Des Moines Iowa
2016 S Max Sofitel -
I think the manual is outdated, and I'm not sure why they ever recommended 35 psi. I heard one of the guys doing work on T@Bs at Tearstock say that he had put 45 psi in the tires of a trailer that he had been working on. I also have read that some on this forum run at 35 psi. I no longer have the original tires on mine because I ran them at 35 psi for a year after I bought it. Wore and pitted the tires on the outside, one of the signs of under inflation. I suppose everyone has good reasons for the pressure at which they run, but since I put new radials on last year, they stay at 45 psi.
I keep mine at 35, but ours have the 15 inch tires and 3500 lbs gross weight, so 50 pounds and it rides like a rock!
The Dutchmen T@Bs recommend 44 PSI on the car tires.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
I checked mine today. The dealer was the last one to touch them and both tires were at 42 psi. I'll leave them where they are since I had no issues when towing.2016 T@b S Maxx
2011 Subaru Outback
Rockford, Illinois -
I initially used 45 psi and then took a long trip and when I returned home I found that the outside edges of the tires had worn. In checking I found the I had around 34 psi so it pays to check the air frequently-especially prior to a trip. I first thought I overloaded the T@B.
- 916 Introductions
- 72 Teardrop Groups & Links
