I recently acquired a 2024 Tab 400 Boondock.  The shower pan needed a good scrub.  When cleaning I notice that water will not properly run into the drain.  It seems to collect around the drain and to the corners of the pan.  It seems maybe the drain is pushed up a bit too high.  Anyone with similar issue?  I had to work the remaining water into the drain by hand.  Another issue I notice, I was told to bias the level of the trailer to the drivers side so the CoolCat will drain properly but the shower drain on the TAB 400 is to the passenger side.   Comments or thoughts?  Am I error in my understanding on CoolCat?  I am coming from a Tab 320 and no issues with draining on that unit.
0 ·
Maybe NuCamp made these a bit too long, causing the high spot...? I don't recall having a block next to the drain on my rig, maybe yours do...? Moving them away from the drain might help. Making them shorter would also help, but is tricky to do.
Also while down there took a shot of the new Transcore floor that is visible due to the cut to allow the p trap. The p trap though is rubbing on a sharp corner of the floor so likely I need to fix that or it might rub a hole in the flexible pipe. Seems the hole placement didn't align with the p trap.
(Took another pick with a yellow level to get a better view of the gap that was previously negative.)
The rubber P-trap was also pressed into the edge of the floor cutout creating a slight indention. I discovered it one month past my one year warranty and NuCamp wouldn't pay to have it fixed. I had to pay the dealer to widen the floor to create a gap.
Sold 2023 Tab 400
Sold 2018 T@B 320S
