My Champion 2500 inverter generator (gas; 201490; 20A) can handle the Air8 AC in my 2024 T@B 320S BBC, but starting it up sounds painful.
The first Champion 2500 I bought failed last March. Champion quickly replaced it and recommended a Soft Start to ease the stress on my Air8 compressor, and the generator.
Circling back to look into a Soft Start. I want one that I can mount in the Air8 compartment. There is plenty of room. But there are so many Soft Start brands and devices….
I plan to head to Kingman, AZ in mid October, when the highs get into the 80s.
Then when Quartzsite, AZ temps go into the 80s in November, I plan to head over and spend the Winter there.
Hoping to get some feedback on make and model y’all are using, so I can get this done before I head out.
TIA
I started researching on whether I could move it into my T@b 320 and hook it up to my Air8 AC. From my research I learned it could be hooked up/wired in. It is feasible but I haven’t gone ahead as my generator handles the surge just fine, I’ve never tripped the 20 amp circuit breaker. If I get a smaller generator I may proceed.
Micro-air.com makes an rv version but it’s pretty much the same one I have.
John, Northern California
2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter|EMS|SoftStart)
2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
https://revkit.com/donmontalvo/ | https://donmontalvo.com
I tested in a BLM spot. Started my Champion 2500 gas generator, made sure it is NOT in Eco mode. Started the Air8, no compressor “thump”! After a minute I set it to Eco mode and it ran fine for 10 hours, with thermostat set to 68°.
So this Winter I may head to Quartzsite, AZ sooner than last year now that I can run the Air8 off my generator. I carry a 5 gallon fuel cal on the spare wheel of my JLUR so I can run the Air8 for 50 hours if I keep filling the generator tank. Last year I got there in early November, I think I will go in early October.
I used two long screws to securely attach it to the 2x4. It comes with 48" of cable so can mount it anywhere. I like it here so if I ever need to take a peek at the LEDs, I only have to lift a cushion a couple inches. Very happy.
