Soft Start choice
donmontalvodonmontalvo Member Posts: 187
My Champion 2500 inverter generator (gas; 201490; 20A) can handle the Air8 AC in my 2024 T@B 320S BBC, but starting it up sounds painful.
The first Champion 2500 I bought failed last March. Champion quickly replaced it and recommended a Soft Start to ease the stress on my Air8 compressor, and the generator.
Circling back to look into a Soft Start. I want one that I can mount in the Air8 compartment. There is plenty of room. But there are so many Soft Start brands and devices….
I plan to head to Kingman, AZ in mid October, when the highs get into the 80s.
https://weatherspark.com/h/y/2293/2025/Historical-Weather-during-2025-in-Kingman-Arizona-United-States#Figures-Temperature
Then when Quartzsite, AZ temps go into the 80s in November, I plan to head over and spend the Winter there.
https://weatherspark.com/h/y/2278/2025/Historical-Weather-during-2025-in-Quartzsite-Arizona-United-States#Figures-Temperature
Hoping to get some feedback on make and model y’all are using, so I can get this done before I head out.
TIA
  • TourDeForthTourDeForth Member Posts: 126
    I have a micro-air soft start installed on my home 2.5 ton AC that I installed myself. It worked well until my compressor finally seized.
    I started researching on whether I could move it into my T@b 320 and hook it up to my Air8 AC. From my research I learned it could be hooked up/wired in. It is feasible but I haven’t gone ahead as my generator handles the surge just fine, I’ve never tripped the 20 amp circuit breaker. If I get a smaller generator I may proceed.
    Micro-air.com makes an rv version but it’s pretty much the same one I have.
    John, Northern California
  • donmontalvodonmontalvo Member Posts: 187
    I called SoftStartRV with questions. The circuitry is sold by different companies under different brand names and models. I ordered theirs for their warranty. Should arrive tomorrow, seems like a simple mount and splice job. Will post a follow up.
    edited September 2025
    I received the SoftStartRV SSRV3T. I opened a ticket and got a call for an install walkthrough. It was simple and quick. Luckily I had wiring tools, including a wire cutter/stripper, a ratchet crimping tool, some male/female spade connectors, some shrink wrap, a heat gun, some grommets, and some Aleve for the contortionist moves in the tight space.
    I tested in a BLM spot. Started my Champion 2500 gas generator, made sure it is NOT in Eco mode. Started the Air8, no compressor “thump”! After a minute I set it to Eco mode and it ran fine for 10 hours, with thermostat set to 68°.
    So this Winter I may head to Quartzsite, AZ sooner than last year now that I can run the Air8 off my generator. I carry a 5 gallon fuel cal on the spare wheel of my JLUR so I can run the Air8 for 50 hours if I keep filling the generator tank. Last year I got there in early November, I think I will go in early October.
    I used two long screws to securely attach it to the 2x4. It comes with 48" of cable so can mount it anywhere. I like it here so if I ever need to take a peek at the LEDs, I only have to lift a cushion a couple inches. Very happy.
    Did they give you an accurate wiring diagram that you can share? I’d like to compare it to mine.
    The tech asked that customers call them for help.
