New to camping and just purchased a 2017 Tab 320 Outback and planning a two month road trip traveling the States. Most all of the time I will be staying overnights without shore power. Ideally I would like to be able each evening to power a tv, lights, and the fan. Currently in place is the factory SAE port and 100 ah lead acid battery. There is a factory luggage rack with spare tire mounted on the rear. Mainly need to charge when driving during the day so that I have power at night. I am not technically inclined, but I am attention detailed and able to follow instructions. I need help in designing the ideal system that would have solar panels mounted on the camper. Specifics as to brands and size of all the necessary components, installation from start to finish, and placement would be greatly appreciated Accompanying pictures even better! Before I posted, I scanned the first 20 pages in Battery/Electrical & Solar and did not find a post that was comprehensive enough. If you know of one that exists, please point me in that direction. I know this is a big ask, and sincerely appreciate the help.
0 ·
Not sure what you mean by "plug and play kit." The guys at Sun Powered Yachts would send you all the parts you'd need to install panels on the camper, as you originally mentioned.
Also not sure why you mention the rack on the back. Are you envisioning attaching the panel there? I think that at least one person has mounted a rigid panel on a rack. @AldebaranJill?
1. Call Sun Powered Yachts for a complete system that I can install.
2. Due to simplicity, go with the LiTime lithium Group 24 battery and possibly stack two.
3. Install a DC to DC charger. Hopefully SPY can help with this or if not, I will research existing posts on this subject as well as how to stack and wire batteries.
I live in Evansville, Indiana. If anyone knows of a company that does installations nearby, I would absolutely go that direction. Nearby larger cities are:
Louisville,KY
Bowling Green, KY
Nashville, TN
Indianapolis, IN
St. Louis, MO
Thanks again for all the great advice. I am excited to get this installed and start my road trip.
Only had to use it in Quartzsite, AZ, when I stayed a little too long and temperatures got high, and again in Butte, MT, when it rained for several days in a row and my two 200ah batteries drained.
Unfortunately nuCamp haven't latched on to 12V air conditioners...maybe in future models. Until they do, you'll need a generator or to splurge on shore power.
I plan to purchase some 200W folding solar panels, since I already have 480W on the camper (380+100).
Good luck with your project.
https://revkit.com/donmontalvo/ | https://donmontalvo.com
We all have different needs and expectations, but this is working for us.
