Customized 2017 T@B CSS, New Lithium Battery and Converter, Good value!! Northeast Ohio. $19,500
Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,012
Please contact Sharon with questions or interest:  CSS4Sale2017@icloud.com
Original owners, non-smokers, no pets, everything works as designed, excellent condition!  Ideal for those new to RV travel as purchase includes lots of necessary camping gear!  A couple of advantages of the clamshell design is the available storage and simple, accessible plumbing for routine use and maintenance.  The original, high quality cushions remain comfortable with like new original upholstery and seats with washable denim slipcovers.  Portable solar ready with installed port and pigtails.  Includes 200 watts of portable solar with all necessary equipment for out-the-door solar power.
All major maintenance completed at the nuCamp service center including every 2 year glycol changes, regular wheel bearing repacks, and brake inspections. Stored in an indoor, climate controlled facility.
Quality built by an "A" team at Pleasant Valley Trailer Company when customizations were permitted during production.
Custom upgrades during production:
50 Qt. ARB compressor frig (wired to 12 and 120 V), aluminum slide and flush galley counter top
Large front cabinets to replace standard bench
Premium Sofitel white counters and Lagun table top
Exterior Lagun table mounting bracket
Galley sconce lighting and under-cabinet LED lighting
Victron BMV-700 Battery Monitor (Since replaced by Smart 712)
Eliminated USBs, added 2 more 12V + galley and front 120V outlets
MaxxAir Fan Deluxe Model 7500K
Factory designed, aluminum battery box
Recent adds and maintenance:
  • 2025
  • WFCO 8735 Auto Detect converter with jumper
  • Replaced LPG/CO detector
  • LiTime 140 Amp Lithium battery
  • New Front window with metal hinge
  • Replaced MaxxAir fan lift arm gear box and circuit board
  • Alde glycol exchange
  • Wheel bearings packed, brakes inspected
  • 2023
  • New tires x 2 - Carlisle ST 205/75R14
  • Alde glycol exchanged to Rhomar
  • Replaced toilet seal
  • Replaced LPG hose and regulator
  • 2022
  • Aluminum Diamond Plate tongue box
  • Galley sink Hepvo valve
  • Replaced gray tank SeeLevel sensor
  • 2021
  • New 50 qt ARB frig/freezer with remote monitor (replaced original ARB)  (2021)
  • BMV Smart 712 (Replaced original 700 model)  (2021)
Past additions:
Aluminum stove wind break
High altitude Alde propane regulator
Tank Check - LPG tank monitor
Threaded fresh water fill inlet
Valterra sewer hose carrier
Toilet shut off valve
Single tank outlet
Removable jack plate
Poplar bed slats x 3
Double jack wheel
RV step rug
Fresh water tank:  11 gal
Gray water tank:  18 gal
Black tank:  8 gal
Q
Standard 2 burner LPG stove, sink, water pump, Alde hydronic boiler.
Hepvo valve replaced galley sink p trap for improved space.
Water pump and mixer valve - original.
ARB compressor frig slides out.
Bed slats using half large poplar boards cut out for Lagun table.
Use the Lagan table outside and use the bed slats like a coffee table.
Cabinets pass thru to the galley.
Original BMV 700 monitor (now Smart BMV 712 with phone app.).  Charging center is only 12V outlet.
Original A/C works well!
Alde hydronic heat and water digital control and A/C air intake control.
Toilet shut off valve.
New WFCO 8735- AD converter with jumper and new LPG/CO detector.
Brahma wheel lock - great security!
PahaQue side tent - extra set of fiberglass poles, too.  Red and white window awnings x 3.
INCLUDES:
Classic Accessories PolyPro cover
Laputa AND Hasika sun shelters.
Original spare tire, 12T bottle jack, hitch ball wrenches.
New LiTime 20 Amp Lithium Charger and case.
2 Renogy 100 watt portable solar panels, Victron MPPT 75/15 controller, 30 feet of marine grade extension with MC4 connectors, miscellaneous connectors, tools, fuses, etc.  4 inflatable solar Luci lights!
Sherline Tongue Weight Scale
Lynx Levelers, Camco stabilizer pads, Anderson Leveler, Wheel disc, original wheel, stabilizer rank, Ryobi 12V drill with stabilizer bit
50 feet water hose with reel, water jugs with funnel and fill adapter, pressure regulator, spare pump filter, etc, sewer hose support, spare black and gray tank valves, every sewer hose and connector known to man, 12 gallon gray tank with hose, sewer donut, Happy Camper, antifreeze and Alde Rhomar glycol.  (There is more sewer hose in the mounted Valterra sewer hose holder.)
King Camp canvas Camp Kitchen with miscellaneous camping cooking gear, 12,000 BTU butane burner, original T@B cutting board.
Stake box with…stakes, mallet, jack post foot, previously noted Ryobi drill, grease gun and Meguires Plastic window polish.
Tool box with useful stuff including fuses and the coveted Robertson screw drivers.
PahaQue side tent, tarps and tent rug, King Camp 5 ft aluminum table, 32 x 32 Mountain Alps aluminum table, step stool,  high back chairs and 2 sun shelters used over the galley.
Wing Walls with fiberglass poles.
12V fans, extension poles x 2, collapsible broom and rake, clothes line and dust pan set.
Heavy duty mattress pad, 2 sets Short Queen sheets, Queen fleece blanket, 3 awnings, nuCamp blankets.
Coleman Fold and Go propane grill, 5 gallon LPG tank, 6 gallon water jugs.
  • Tabaz Tabaz Member Posts: 2,412
    OMG - I thought I was anal-retentive!!! The owner labeled all the water lines?  Who does that?  Whoever buys this will be getting a seriously well-maintained trailer by a meticulous owner.  Wow.  Simply wow.
    One further thought.  I think the 2017 trailers were the best NuCamp ever made (I own a 2016).  They have the wonderful wood ceiling and moved the guts of the Norcold frig to the outside wall of the trailer.  The build quality has gone down from there.  Next month marks the 10 year ownership of my trailer.  Would not trade it in on another unit - including a new NuCamp model.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,012
    @Tabaz - I’m a little biased, but I think 2017 was an excellent model year!
