25 - 400 black canyon antenna options ?
MOS2
MOS2 Member Posts: 62
edited October 2025 in Products and Accessories
New here and considering a 2025 400 black canyon . Been RVing for years and a number of rvs owned .
I have never purchased a travel trailer with out a tv antenna.
We travel and don’t stay put in one place long . So need some suggestions . Want to be easy to install with good results .
Thanks , Mike
  • MOS2
    Maybe I posted this in the wrong categorie
    pthomas745 Administrator, Moderator Posts: 4,685
    Welcome to the Forums.....there are lots of different TV antennas owners have used.  Most of the antenna discussion will revolve around "how far are you from a transmitter".
    Some owners have antennas mounted on poles.
    Here is a very old thread with the same basic ideas.
    Many owners simply use the basic "off the shelf" TV antennas, of course.  Here are all the threads for this.
  • MOS2
    Thanks for the reply
      Don’t want any pole mounts . We are travelers. All the tv antennas we had in the passed were stock on the rv when purchased . They worked fine most of the time.
    It need to mount and connect , either inside or out with out any big mod project .
    i guess you can say simple , neat and works as good as standard OEM antennas
    I have a simple pair of old rabbit ears, and one of the nicer "high def" antennas.  The rabbit ears work perfectly.  The real key, though, is how far are you from a transmitter.  There are many web pages that discuss "antenna aiming" that will tell you how far away you are from a transmitter.
  • MOS2
    Never know how far …..as I said we travel and don’t set in one place long .
    is there an amplified indoor antenna that’s made for RVs?
  • GregChris
    GregChris Member Posts: 199
      I made an antenna mount with keder stops, a metal light switch cover, and some 3/4" pvc pipe. The mount slides into the keder and when you tighten the stops in stays where you put it. You can leave it permanently, but I usually take it down. I bought a small amplified antenna that folds flat for storage, mounted it to the pvc, and just stick it up there. there is a coax in the nautilus to plug it into. What takes the most time is figuring out where to aim it, and programing the tv. If your interested I'll try a get some photos. I have maybe $40 in the whole thing including the antenna. Best thing is no permanent changes to your Tab.
  • GregChris
    By the way, I meant leave the keder mount there, not the whole antenna.
  • Mistydawn123
    Mistydawn123 Member Posts: 7
    We have KING RV Omni Go Portable HDTV Antenna works great.
