I'm looking to replace the front trim piece, not the outside pieces, but the very front going from handle to handle behind the front tub. It fits into an aluminum rail similar to a keder rail and is on the very front of the T@B behind the propane/battery tub. I crushed it when I was replacing my old plastic tub with the new aluminum diamond plate. You can see the area that's cracked and crushed in the closeup pic. It looks like it's mainly there to cover the screws. I'm hoping someone has replaced this with something from either a hardware store or Amazon maybe? Any ideas? TIA
0 ·
UPDATE: I copied and enlarged your photo to see it clearer to see if I was mistaken as to what you need. It appears that what you are actually looking for is the upper and lower strips (but probably a single trim piece) that are curved on each side and hold the screw cover insert. Is that correct? If so, I'm not sure what that is called, but the closest I could find is "Rub Rail Trim", so you might try searching online for that. Better yet, it might help to contact nuCamp and provide a close-up photo to them so they can provide you with a part number, or what it is called so you can search online for a replacement.
Amazon Trailer-Elixir-Rigid-Insert (1/2")
Here's a link for a heavy duty, but flexible 1" wide trim, but I don't believe that is what you are looking for:
Amazon - RV-Designer-E461-Heavy-Flexible-Insert (1")
It looks to me like the "rigid" insert I included in my earlier post is the piece you are looking for, but maybe I am just not clear on what was actually smashed/broken. In the photo below, the trim with the red arrow pointing at it is that insert. The blue arrows point to the upper and lower curved outer edges of what is likely a flat piece of trim (on the backside), which has a channel for the rigid trim to be inserted into.
Amazon - molding-Insert-Camper-Travel (7/8")
