When at a campground with hook ups (and hooked up) , what is the 'school of thought' about whether to leave the grey water tank valve open, so that it constantly drains, or closed and drain periodically as it fills up? Has anyone had issues with 'swamp gas' coming up from the sewer hook up and triggering the propane detector? Cheers!
Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California
0 ·
John, Northern California
I don't even hookup the drain hose until it is time to dump.
Also consider turning-off the city water source when away from trailer for the day . . . so an unexpected plumbing leak does not flood the trailer.
Adventures: 58 Nights: 405 Towing Miles 50,180
Volvo XC-40
The two sinks in the trailer have traps. they should stop sewer gasses from entering the trailer. I don't connect to get a better flush from the tank. The more full, the better it drags out anything in the bottom of the tank.
If you were going to use the shower, you may want to let the gray system drain.
"Just Enough"
