Winterize with 12 volt compressor?
Is using a 12 volt compressor to clear plumbing really working? Has anyone confirmed that it either works or doesn't? I'd like to believe that mine does, but I haven't gotten any visual proof. FWIW, the compressor has done its duty on bike & car tires
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
Does your compressor have a pressure gauge?
If yes, close all sink, etc faucets. Run compressor to about 40PSI, stop compressor, open a faucet tap or low drain. Repeat process until only air comes out or all taps/drains (one at a time).With a small compressor the process will just that longer, the less water in the system the longer it will that to reach 40'ish PSI. I use a small compressor, old Black & Decker, just fine - - - just takes some time.'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 59 Nights: 411 Towing Miles 50,3501 -
Compressor has a gauge - that's never budged when attached to intake. Valves are open; attempts done at Nautilus's 45° settings.
Compressor gauge has worked up to 50 psi on bikes.2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno0 -
Dope slap! Procedure works when done in expected order.2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno1 -
Not a direct answer to the question but maybe of use to folks. On my 2020 400 had always gone the antifreeze route. Decided to blow the lines last winter although with a larger tool compressor. Worked fine except when fired up the rig in the spring discovered that plastic filter screen housing at the base of the water pump was fractured. It’s a bit of a water trap that air pressure doesn’t seem to clear out. Fracture means you can’t pump water out of the water tank because it’s sucking air through the fracture.2020 Tab 400 BDL with Solar2013 Tacoma TRD with towing packageVermont0
@HBarry, frankly, it is surprising that more compressor fans don't report similar problems. Most home compressors lack what good commercial compressors have, a drier. Because of that, the compressor blowout method succeeds in removing most of the water from your system while blowing in moist air. The only sure-fire method to remove water is to push anti-freeze through. It fills all of the voids and sits in all of the low spots where moisture would otherwise collect. Once you have repaired a few valves and faucets, it becomes much more obvious.0
One of the things about winterizing that has gotten lost with the Nautilus panel instructions is ..how to protect the pump. There are many threads here in the Forums that discuss simply disconnecting the pump supply lines and draining them and the pump. I guess it is something we should try to hightlight more.
Towed by 2014 Touareg TDi1 -
Yes, and emptying the filter cup.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
