Overhead LED in Tab400
AndreO
Member Posts: 88
Has anyone taken the Overhead LED down on the Tab400? I'm seeing some black in-between some of the LEDs. I suspect by thier spacing it could be corrosion. The problem is I can't determin how the fixture is mounted. Do the chrome knobs unscrew or is it just snaped into the celing somehow?
AndreO
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
Ontario, Canada
2018 Tab 400
Issue solved, I figured it out. The chrome caps come off by slipping a exacto blade between them and the clear plastic. Then there are 4 screws holding it to the ceiling.Once I cleaned the frosted plastic face plate you could clearly see that the black spots are just micro resistors for the LEDs.
AndreO
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat2
