Can't figure out where to plug in spark electrode assembly
ezusmanis
Member Posts: 23
I have a 2019 TAB 400 and I had to replace the burner. To do that, I unplugged the spark electrode assembly from the burner control. Now, I can figure out where to plug it back in !
Does anyone have a picture of where it plugs in or a description. You should be able to follow the wire from the spark electrode on the burner assembly to where it plugs into the burner control.
2019 T@B 400 BD Lite / '95 4WD GMC Yukon
Oh, it's a Norcold N31042019 T@B 400 BD Lite / '95 4WD GMC Yukon0
The installation Manual has this Wiring Diagram.
It appears you need to locate Power Control Module,
on that board there will be a Burner Control Module [BCM].
The BCM has two connection 'connectors', a single piece 3-pin connector, and another 3-pin (undefined) connection block, the Electrode goes to the first connection point.
Trick will be finding that 3-pin connection block as Installation Guide only has the diagram.
You're right the biggest issue is locating the connection block. I do remember seeing the red connector when it was plugged in. Maybe someone could take a picture of where the connector plugs in!2019 T@B 400 BD Lite / '95 4WD GMC Yukon0
@ezusmanis, it might be easiest to call the manufacturer. They can probably send you a photo (or instructions) via text/e-mail.
Greg & Marlene (Tucson, AZ)1
