I have a 2006 Tab that needs a tongue jack. It looks as if the original was inside a round slot in the V of the frame. The current one is a bolt-on to the side of the frame, which has bent the frame a bit. Looks like it may not have been the proper side bracket. Is there a replacement for the original center jack, and is it possible to bolt or weld it in place? Doesn't look like much surface room for that, or is the outside/one-side of frame with a proper bracket sufficient? Any advice would be greatly appreciated.
                1 ·
