What is the difference between Dometic Furnace and Heat Pump Modes
I understand what is supposed be be a furnace and what is supposed to be a heat pump. But last night, while on shore power,  when I tried the furnace, it was 42 outside, and didn’t feel any heat. The heat pump, however,   worked great. When do you set it to Furnace?
Karen and Chris
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey
  • B0atguyB0atguy Member Posts: 253
    The "Furnace" option on the dometic panel is not used in a NuCamp 400 . Its just an extra setting incorporated into the dometic panel that most other rv's will use , but does nothing in a NuCamp with the Alde heat system . The heat pump setting will run the cool cat heating .
    The dometic panel basically runs just the cool cat , and the alde panel runs the heat and hot water system .
    Guess its not technically just a "cool" cat in a nucamp , its also a warm cat as well . lol
    Just no furnace option built into it .
  • CruiserCamperChrisCruiserCamperChris Member Posts: 91
    Thank you!
    Karen and Chris
    Dallas, Texas
