2019 TAB400 - Lots of add-ons : Fully Loaded Off-Grid Camper (central PA): – $24,500
mtwinchmtwinch Member Posts: 1
TAB400 - Fully Loaded Off-Grid Camper (410W of solar / 400Ah of high-efficiency lithium battery).
Ready to hit the backcountry without a single hookup? This 2019 tab 400 is your ticket to unlimited off-grid freedom! Powered by 410W of solar on the roof (with expandable panels) and 400Ah of high-efficiency lithium battery bank, you'll generate and store more than enough energy to run appliances (to include A/C), charge devices, and light up your adventures. It's perfect for boon-docking, remote work, or full-time life.  Possibilities are endless.
For sale (we are second owners) of a well-maintained 2019 T@B 400 in excellent condition.  This is a pre-Covid build (December 2019) and we have had no issues with any of the systems or structure.  Comes with the reliable and super-quiet Cool Cat air conditioner, 900w microwave, 3.7 cu ft. 3-way fridge, backup camera hook up, TV, stereo and more.  The electrical system has been upgraded for extended off-grid use with 400ah of battery, a 410-watt solar panel, a 6000w peak/3000w continuous inverter and all needed switches, fusing and controllers.  It has a soothing green, tan and gray interior with infinity flooring and birch wood cabinets.  It’s very cute and easily drivable rig that has been carefully maintained.  It has new Goodyear Endurance tires with less than 1000 miles on them and bearings were packed spring/summer 2025.  We have all manuals.
More Details:
  • Central Heat and Hot Water System (Alde®3020)
  • 900 watt Microwave  (High Pointe) – runs on shore power or battery
  • 3.7 cubic foot 3-way Refrigerator (Norcold 3104) – great for off-grid use on propane
  • 10,500 BTU Air Conditioner with heat pump (Cool Cat) – about 5 hours continuous use on battery)
  • Custom Birch table with folding front (see pics); original table also included.
  • Queen bed (79”x58”)
  • Froli™ Sleep System
  • Second sleeping area in front
  • Upgraded Fantastic Fan – variable speed, thermostat, rain sensor (FV807357)
  • Backup Camera ready
  • Sound system with CD/DVD, AM/FM and TV (Jensen)
  • 410 watt solar panel (Panasonic EverVolt EVPV410HK)
  • Solar Controller (Victron SmartSolar MPPT 100/50)
  • 400 amp hour LiFePo battery (EG4 LL) with monitor
  • 3000 watt (6000w peak) pure sine wave inverter (Giandel PS3000QBR)
  • Transfer switch (Go Power TS-30)
  • Electrical Management System (Progressive Industries EMS-PT30C)
  • Weight Distribution hitch with sway control (Reese Steadi-flex)
  • Shore-power cord – 30 amp with 50amp and household plug adapters
  • Classic Accessories Cover
  • Sewage hose (Only used once)
  • Fresh water hose
  • New Goodyear Endurance Tires (put on in spring of 2025).
  • New TPMS purchased 2025
  • New water pump
  • New proven Industries Lock - Black (Billet 6061 Aluminum) - Specifically made for the tab 400
