Solved - Anyone have a link to buy the CS-S mounted overhead hatch led round light
Lawyerboy
Member Posts: 141
The button on my 2018 320 CS-S light on the rear galley hatch has always been difficult. You press it, and it flickers but does not turn on. It takes many attempts to get it on. I would like to replace it, but wish to use Amazon if possible, for a quick ship option. TY
This is the version with a dimmer built in.
https://www.amazon.com/dp/B00ODVEWPG?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_6
TY Ordered.0
Installed, but boy, the wires inside the hatch have no movement so I cut the wires at the old light as close as I could get to be able to then wire the new to the wires inside the hatch, but really tedious work where there is very little wire to work with inside that hatch. Light is same brand, but with a better button for sure. TY.1
I didn't change the hatch light but both interior lights for the dimmer feature. The wiring inside was not so challenging.
Glad to here your light is working.
Have fun...
- 417 Service/Maintenance & Recall Notices
