Solved - Battery change - what to do with heater cable on BattleBorn
JPP
JPP Member Posts: 4
I am switching out the BattleBorn 100 ah Lithium battery, that came stock on the T@B 400 BD, with an SOK 208 ah lithium.  The BattleBorn has an externally switched low temperature heater in their battery.  There is a separate cable attached to the BB battery to activate the heater. I’m wondering what to do with this cable once I disconnect it?  I assume I can just cap off the end of this wire and leave it as is?  The SOK battery does not have an external switch, rather it has an internal switch that activates a heater if charging at temps below 2C.  I attached a pic showing the BB battery with the red heater cable wire attached.  Thanks.
T@B 400 Black Canyon, 2025
Chev Colorado
St Catharines, ON
    qhumberd Administrator, Moderator Posts: 844
    I don't have this setup but was interested in how the heater worked so I found the attached from BattleBorn. Maybe that will help as it looks similar to yours.
     Inside the manual it says:
    Step Three:  Deactivating the Heat-Enable Function To deactivate the heat-enable function on your heated Battle Born Battery, simply remove the heat-enable jumper wire from the heat-enable post. Remember to tape down the end of heat-enable jumper wire with electrical tape and cover the ring terminal so it does not make contact with other live wires or grounds. Be sure to put the heat-enable screw back into the post so you don’t lose it.
  • Grumpy_G
    Grumpy_G Member Posts: 748
    Yes. I think one of the wires on the positive post goes to the switch so you can remove that one too.
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 582
    Hi,
      I also removed it my 360, when I upgraded my battery.  I used that  wire and circuit  for  a new 12V plug toward the rear (where there is not one).  The battery heater wire in our 360 went to a dedicated fuse in the WFCO.
    What are you doing with your 100 aH battery..I've been trying to sell mine for $450 for a while but no bites.  Trying to figure what i might use it for.
    2025 360 CS
    Southern Maryland
  • donmontalvo
    donmontalvo Member Posts: 187
    edited November 2025
    JPP said:
    ...[snip]...There is a separate cable attached to the BB battery to activate the heater....[snip]...
    The wire is connected to a toggle switch to enable or disable the battery heat.
    My 2024 320S uses a lit toggle switch, as I show on my DC wiring schematic, bottom right:
    https://i0.wp.com/donmontalvo.com/wp-content/uploads/2025/10/20251016-Camper-schematic-1800-scaled.webp
    If your SOK doesn't need it, it'll be an unused switch I guess.
  • JPP
    JPP Member Posts: 4
    Thank you all for comments.  Question answered.
    Yoshi asked: “ What are you doing with your 100 aH battery..”
    Well, I was going to try and sell it, same as you.  See how it goes I guess.
    Chev Colorado
    St Catharines, ON
