2008 Dutchman T@B trailer FOR SALE
1Jack_Diane21Jack_Diane2 Member Posts: 4
$8,500 - located in El Reno, Oklahoma (near Oklahoma City)
contact information: jack.earl@alumni.ou.edu
Bought new and has been garaged most of its life.  Selling only because we want a larger unit for extended traveling.
This trailer is easy to pull - we use a Subaru Outback.  The trailer is light enough to be maneuvered by hand in campsites.  A classic looking teardrop style which always attracts attention at campsites.
Unit has the following:
propane heater
2-burner propane stove
12V compressor fridge - cools great - not a 3-way fridge
120V heat pump - cools or heats - can cool inside very quickly
new Firestone tires April 2023
new battery May 2025 - 320 CCA AGM High Rate Series Battery
Pahaque awning with high-quality aluminum poles for awning
storage tray added on back
front mounted spare tire
under-counter DVD player
under-counter rechargeable LED lights
additional extras included
outdoor adjustable step
12V battery charger
wheel studs - makes removing and replacing tires much easier
Caster Wheel Dolly (Pack of 2) - used while storing trailer in garage
More Details:
2008 Dutchman T@B trailer (a Thor Company)
VIN 47CTTTG118B70xxxx
May 2007
Alufiber with Cherry trim
L-Shaped floor plan
T16-Q "Queen Bed"
  • hammerstonehammerstone Member Posts: 30
    Hi there Jack and Diane.  I'm interested in your trailer, i have a 2007 and planning to replace the 3way with a DC, but thinking i might just sell mine and buy yours.  A few questions for you.
    Spare Tire:  What size is the spare, and what size are the tires on the trailer?  Is the original spare tire rack still mounted under the back of the trailer?
    Reefer:  The install looks very nice!  Can you tell me the make and model of the unit so i can look up capacity, amp draw, etc.  Was it self installed, factory installed, or dealer installed?  You seem happy with it, do you have any experience on how long it can run with your new AGM battery?
    Rear rack:  do you have any pictures of how the rack is attached?  Was this a factory install or DIY or dealer?
    thanks in advance...
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,056
    @hammerstone - if they don’t reply, please contact them via their listed email:
    thanks sharon no reply so i'll try the direct email.
