Lagun Table mounted directly on post saves space
I found that the Lagun table in our tiny 2025 T@B 320S took up too much space when mounted on the arm. I designed an adapter that I 3D printed to allow the table to mount directly on the post without the arm. The files to print the adapter can be found at Printables, and a full write-up can be found on my blog at Lagun Table Improvement
2020 NuCamp T@B 320S Boondock
1995 Suburban :-)
    Can’t tightened to prevent spinning?
  • BandB
    BandB Member Posts: 75
    @GaryStebbins this is a great idea! Thanks for sharing all the info. What do you do with the table while on the road? Does it just move around freely or do you take it off the post?
  • GaryStebbins
    GaryStebbins Member Posts: 3
    @BandB, Sorry to be so late responding. With it sitting on the post without the arm, there is no off-center weight, so it doesn't swing around. We often just leave it on the post when we're traveling.
    1995 Suburban :-)
