Have a set of 4 keys from our 2024 T@B 400 .
Our 400 was just at NuCamp for some service / warranty work , and they changed our entry door lock assembly . The new door lock assembly now has different keys than we original had and our old keys will not work .
If anyone has a T@B that uses key # 8010 , I have a set of 4 that are of no use to me .
Just PM me if you want them , and I will send them to you . These are CUT 8010 keys that will ONLY work if you already have 8010 key set .
Hope someone can use them !
EDIT - GONE !
St Catharines, ON
For instance - I asked NuCamp for a couple extra keys , since they changed out my lockset . Literally , in about 10 seconds , they came back with 2 more keys for me . Just a quick trip to the parts dept. in the back .
Check your key numbers . I will bet they are pretty close in number , or even the same !
Just trying to help another NuCamp owner who may have this number key , if they want some extra keys for free .
2024 NuCamp T@B 400 BD, Charcoal / White
So, how many different keys might there be? Or, what is the repeat factor?
Gosh, this is a rabbit hole…
St Catharines, ON
Luckily ,I do believe that NuCamp does use a different type of lockset / key , than most other RV manufacturers . So it would probably have to be another NuCamp owners key that might work .
I am completely comfortable with my 400 when its locked . It just keeps the honest thief's out of it . If someone wants to break in , this little door lock is not going to stop them . Its not like I keep anything of value inside it , like its a safe depot box or something.
If you want a real eye opener look up RV key CH751 key , lol .
... but I won't lose any sleep over it.
