Do Snap Pads impact grounding?
System
System Administrator Posts: 192
This discussion was created from comments split from: Snap Pads.
  • RCB
    RCB Member Posts: 254
    Do such  pads set under the stabilizer pads and hitch support eliminate any grounding when boon docking ?  Without them, there is definite contact with the ground but perhaps not as effective as a ground rod. When plugged in, the RV is effectively grounded through the electrical distribution ground.
    Sorry, this comment is changing the subject of the thread. Pls move it if necessary.
    400 - 2019
    St Catharines, ON
  • rcarlson1957
    edited December 2025
    Don't think so. Since the roof skin is aluminum on our campers and there is also some aluminum framing I think the Faraday Cage Effect comes into play which means if a direct strike hits the metal exterior (like an Airstream or aluminum-roofed trailer) the current travels over the metal surface, discharging to the ground, similar to how your car protects you. If it didn't then you'd have the same problem anytime the trailer stabilizers weren't lowered. So think it's ok.
    2018 TAB 320S
    2020 Honda Ridgeline RTL
    North Texas
    Trips - 50 Mileage - @67k
