Hi, 2nd owner of a 2023 Tab 400. Looking to add a portable solar panel. Previous owner installed an SAE port near the cargo bay with the battery disconnect switch. I believe he had an additional MPPT installed, but removed it prior to sale. The cables from the SAE port end after about a foot inside the cargo bay. I understand I have two options: One - install an additional Victron MPPT either 100/30 or 100/50 or wire the SAE directly to the battery if I purchase a panel with its own solar controller (the easier route).
What is the benefit(s) of going the more difficult Victron MPPT route?
Madison, WI
2023 Tab 400 Boondock
2018 Jeep Grand Cherokee 5.7L
0 ·
Trips - 48 Mileage - 63,452
I recently also bought a Renogy 220W folding solar panel. I made sure it did not come with a PWM controller. Lucky that it didn't. My JLUR has a Renogy DCC30S (DC to DC with MPPT) so it's 12V 100Ah LiFePO4 is charged whether I'm camping or driving.
https://revkit.com/donmontalvo/ | https://donmontalvo.com
I only use the suitcase for longer stays and for sites with lots of shade, nice to be able to pick up some solar by moving things around. Seems to work fine. As far as I can tell, the solar production from the 2 systems "adds up". Some online sources say that the lower (or higher) voltage/current source blocks out the other one but that hasn't been my experience. I've confirmed the charging current via the battery BMS. It would probably work better if I moved the suitcase controller to the battery compartment to compensate for cable voltage drops, but I haven't gotten around to it yet. Not sure how much difference it would really make anyway.
I think a portable panel is a great option. The advantage to one with an attached controller is flexibility, you can use it for other things. A controller in the T@B gives better options for controller choices as well as a bit better efficiency especially with long cable runs. Not sure which wins for cost...
Just make sure you test & match the polarity of the SAE port to your external controller and/or panels!! I believe it is the opposite of what is "normal" for an SAE setup (like for motorcycle battery charging setups).
Poughquag, NY
