We have a 2022 Tab 400, with the standard two AGM batteries. Also the Victron shunt. I want to swap out the batteries for a Li Time 230ah lithium. Can anyone walk me thru the install and what the final setup looks like once there is only the one battery? Thanks
0 ·
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
https://www.litime.com/products/12v-280ah-plus-lifepo4-battery
2019 Tundra Crewmax aka Hoss
SE Louisiana
Bernadette / 2020 (8/2019) T@B 400 BD / 2023 Honda Ridgeline / St. Louis region
https://tab-rv.vanillacommunity.com/discussion/19831/2020-tab-400-lithium-battery-upgrade#latest
I initially replaced the original Harris batteries with 2 Renogy 100ah batteries (seem to be great quality). But I wound up adding a 3rd battery shortly after. Camping in the northeast for longer trips can be problematic if you depend on solar! Lots of trees and shaded campsites. My point is that replacing the batteries is a fair amount of work and having extra battery capacity is great, so go bigger if you can!
Poughquag, NY
