Washing the camper, what to do, what to do?
Jay_and_Kat
Jay_and_Kat Member Posts: 284
So we're bad owners, our camper hasn't been properly washed since we bought it and we're changing that this year.  We've got a couple options and we're looking for advice on which is better / which is a "DO NOT"
So, to the options:
  1. Hand wash with microfiber cloths and standard car-washing soap, rinsing with a hose with a sprayer attachment.
  2. Wash using our electric pressure-washer with the "car wash" nozzle on the end and standard car-washing soap, rinsing off with a hose
  3. Taking the camper to one of those "pull in" car washes with the sprayer nozzles and scrub brushes
Pros and cons to each as I see it are:
  1. Pros:  Not likely to damage anything, gets us up close with the camper to look for damage / Cons:  Time consuming, need to work on a ladder for a lot of the cleaning, lots of physical work
  2. Pros:  Less physical, quicker, able to get most of the camper from the ground / Cons:  I'd be concerned about water getting past the seals of the windows, potential to damage the sides / top of the camper
  3. Pros:  No mess at home to clean up, able to get most of the camper from the ground / Cons:  Higher pressure than the home pressure washer so more concern about damage to the sides, water getting through the window seals (or even popping a window.)
Any thoughts, suggestions?
Jay and Kat
Tow vehicle:  2022 Jeep Gladiator Sport S + tow package
Camper:  2022 T@B 400 Boondock w/Norcold 3-way fridge
  • Binghi
    Binghi Member Posts: 404
    Do the first option to avoid leaks in the trailer. Buy a pole-based cleaning system that includes a soft soaping cloth to wash the hard-to-reach parts of the trailer and a squeegee to finish off the windows. You’ll also need a tall step ladder. Takes me about two hours to wash my 400. It’s work for sure, but looks great when I’m done!
  • jbajor
    jbajor Member Posts: 233
    #1!!!
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
    pthomas745 Administrator, Moderator Posts: 4,573
    The sides of the trailer are a thin film of fiberglass over a composite type material.  You should take real care not to use any pressure washer type device on the sides of the trailer.  The roof is an aluminum sheet with clearcoat over it, so it might be able to take a little more pressure, but...I'd still go with something "softer".
    I've washed my trailer in a "coin operated" type car wash, but I used a bucket, sponges, and only the "low speed" sprayers.
    Owners have used practically every product in the car wash aisle.  I know classic Porsche owners, and there are some owners who use products that the Porsche owners use on their show cars!
    This is a search for "wax" which has a lot of threads on what owners use.  I'm a Meguiars fan, and lots of owners use their products.
  • NorthIsUp
    NorthIsUp Member Posts: 197
    I go to the local Blue Beacon Truck Wash. Never had a problem after 8 seasons. You can tell them to not brush the windows to avoid any chances of scratches. They used ionized water, so it dries without streaks and without using towels. With tip, it's about $50. They'll do your tow vehicle for $10 more.
    https://bluebeacon.com/view-all-locations/
    I'm too old to do it myself anymore.
    Jean & Arnie  Nevada
    2019 T@B 400 BL
    2021 Toyota Sequoia 4WD
  • jimcenname
    jimcenname Member Posts: 346
    edited January 17
    I am on the road about 6 months per year so I frequently use coin car washes. After it's wet I use a telescoping pole to wash and then dry my T@B. I use both microfiber and an old bath towel to always dry my T@B. I switched to ceramic wash fluid and it improved water beading. I wash my T@B approximately every ten days.
    2019 T@B400
    Southern California
    Full-timer since 2019
  • Okpete
    Okpete Member Posts: 39
    I would not squeegee the plastic windows if I owned the trailer. Clean with soft sponge like material and dry with microfiber cloth. Final cleaning and polish with Plexus
  • webers3
    webers3 Member Posts: 436
    You are overthinking it. I am washing it in a self service car wash for the last five years, no issues.
  • mx4789
    mx4789 Member Posts: 63
    Definitely recommend getting a telescoping type of car wash mop. The one I have can connect to a garden hose, but I find simply dunking it in a bucket of soapy water works better and avoids having water running down my arms. I can get almost all of the tab (320) from the ground except the very top where the fan is. Then I can just use a step stool. For rising, I just spray the top and sides off with the garden hose.
    I haven't tried to wax it yet since I've only had since October. But, on my truck I use another (dedicated) telescoping car wash mop to buff the wax off the top of the truck. I spray the top with liquid car wax let it sit for a minute and then use the mop to buff it off. I imagine I will use the same method for the trailer when I get around to it.
    2025 Tab 320 S BD
    2024 Nissan Frontier
  • manyman297
    manyman297 Member Posts: 1,434
    If you choose to get on a ladder to wash/dry the roof, DO NOT apply weight to the aluminum skin. It dents ridiculously easy. You can safely lean your hand on the bathroom fan, vent or main cabin fan for leverage. Just don’t lean on the skin.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    ScottG Administrator Posts: 5,669
    I'm lazy, so I typically use a pressure washer for my once-a-year-whether-it-needs-it-or-not T@B washing. I've had no issues with this approach EXCEPT for the time I got too aggressive with some pine pitch and stripped a little clear coat from the aluminum roof. I topped over the damaged with a rattle can and some wax and there's been no further deterioration. If you keep your distance with the nozzle and be particularly careful around decals and such, you should be okay. (But the usual disclaimers apply!)
