Wanted to share our recent project:
We needed more battery capacity to run the refrigerator while boondocking and considered adding an additional Battle Born battery, but given the sale price of the 314ah Epoch Eco ($499) opted to save the $ and run one larger battery vs two in parallel. Went with a non-heated battery because I could not think of a use case where the heat feature would be needed given the battery is under the bed, inside the trailer.
With the added battery capacity, it should allow boondocking for 3-4 days with zero sun and indefinitely with some sun. Previously, we could go maybe 1.5 days running the refrigerator with no sun.
Added 314ah Epoch Eco Battery (non-heated) and removed the 100ah Battle Born (capped off wires for heat switch - can use for something different in the future, if desired)
Installed MRBF 300a fuse to positive terminal on battery for added protection
Installed BMV-712 Smart Shunt to monitor the battery and both solar controllers (opted for the BMV-712 for greater bluetooth range, but chose not to install display since the app is better)
Installed On/Off breaker for the rooftop solar next to the battery on/off switch (ability to isolate rooftop solar for long-term winter storage and towing in cold temps instead of relying on the BMS to protect cold-temperature charging)
Installed Victron MPPT 100/30 in cargo compartment (previous owner installed sae solar port next to cargo compartment but no solar controller - this will allow use of our Zoupw 350w portable solar panels
Disabled tow vehicle charging from 7 pin connector (no longer need to disconnect from tow vehicle during overnight stops + added protection vs relying on the BMS to protect the battery from charging during winter towing)
I used a local RV solar/electrical business to help with the plan & install.
2023 Tab 400 Boondock
2018 Jeep Grand Cherokee 5.7L
