New Inside Table for Lagun Mount
rcarlson1957
Member Posts: 264
Mad a new indoor table for T@B. Just birch plywood with 3/4 aluminum banding. Matches the wine rack and cup holders I'd already done. May put tempered glass on top of it. 22L x 14w x 3/4h. Cut down Laguna vertical mount a bit so it would lay flatter between then beds.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 48 Mileage - @65k
North Texas
That came out nice! Try using a bar-top finish instead of glass, it gives a similar effect, hard glossy finish without the weight of glass.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Nice job with the aluminum banding! That takes a great amount of skill to pull-off so beautifully.2016 Outback 320
Here's another take on a new table. It's made from western red cedar with a black walnut accent. I thought the stock table was a bit too heavy. The stock table top comes in at 7.7 lbs (no hardware) and this new one weighs 4.5 lbs, so there's less stress on the pivot arm and bushings. While traveling, I place a pillow on the cushions and lower the table onto it so it's supported, but this lighter table will be even better. I also made some sliding rails for the underside so the table can slide forwards and backwards.
2021 320S BD
2017 F-150
Coeur d'Alene, Idaho -
I used a tool bench top from Home Depot. $36. Not as nice as those above though.
https://www.homedepot.com/p/Husky-26-in-Hardwood-Tool-Cabinet-Top-for-Rolling-Cabinet-HOCN260001/203949843
Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA
- 916 Introductions
- 72 Teardrop Groups & Links
