There are a few variables that are important to consider. First the TAB. Is it a '25 or ;26 model year and which model 360 the CS or non CS. As they all have different dry vehicle and tongue weights.
Which Durango and how is it outfitted in regards to engine size, tow capacity. design tongue weight capacity and your vehicles gross vehicle weight rating which is max.weight including cargo , passengers vehicle, etc. You don't want to exceed this.
Suggest you look at all these terms and become familar with them. They will help answer if your vehicle is adequate or how close to the upper limit it may be.
2025 360 CS 2021 TAB 320 BD (w/new owner having fun) 2021 Jeep Grand Cherokee Southern Maryland
Absolutely, you can tow any tab, including the 400 with a dodge Durango. They tow just as good as the trucks with a few exceptions when you get into longer rvs.
I tow my tab 400 with a 2018 V6 ridgeline fwd.
You will have zero issues towing since every model is designed to tow within the specs of a tab.
2018 Honda Ridgeline FWD 2020 400 solo Fulltime rving since 2006/ tab since 2021
Southern Maryland
2020 400 solo
