2025 400 cable wiring
Hello. Cannot get reception with Omni king traveler anntena using cable connection with power booster on under bed. Aux, also no reception. However, when I bypass trailer systems and use Omni king power booster ,I get tv reception. Any suggestions.
  • MOS2MOS2 Member Posts: 35
    My 2025 400 came with a wine guard interior antenna  connected to the power boost . It’s located behind the microwave.
    Try  unconnecting   the omin  and then turn on power-boost . Make sure your tv is set to air and scan for channels
  • OkpeteOkpete Member Posts: 38
    Okpete said:
    Thanks, will check out
    After campground, Gresham or, energizing power amplifier acquired major ota channels. However was not able to verify winegard antenna behind microwave. With the power amplifier under shelf would seem to indicate a hidden amplifier.
    When  I purchased my 2025 400 late last fall , I was told by many that nucamp does not install tv antennas .
    A call to nucamp and they told me a limited number of 400 boon docks  had the wineguard interior antenna. My vin number verified this .
    You can remove the micro wave easily . For screws on the trim and it slides out .
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,505
    @MOS2 @okpete Another NuCamp surprise!  I hate when this happens. If anyone can get any photos of this antenna setup, it will help.
    A couple of years ago, NuCamp claimed they had installed a "permanent" water pressure regulator on the 2022 models.  It managed to make it into a few trailer builds, but....it didn't work, so NuCamp stopped installing it.  For a couple of years, owners firmly believed they all had a built in pressure regulator, and owners were learning all about the Famous Yellow Flapper valve as a result.
  • Yoshi_TABYoshi_TAB Member Posts: 566
    edited February 23
    Hi,
     I don't have a picture of the antenna in mine (still looking) but here is a picture of the hidden booster/amplifier (the Winegard small white box..i believe that is it..or maybe it's a splitter, but there is Winegard label  on the it ) in a 360. It's also located in a hidden cubby behind the microwave.   It is USB powered. Another 360 owner showed me a picture of a flat antenna his came with behind the microwave (second picture) , but mine is not located there.  I tried to follow the cables, ran out of arm length and view.    I would think there is an antenna somewhere, since this other device is there.  I emailed Nucamp, and just like the 400.   Nucamp said it was put in some 360 builds, but not all.
    2025 360 CS
    Southern Maryland
    @Yoshi_TAB thank you very much.
