T@B360 bedding
jdkoepsell
Member Posts: 26
Any suggestion of what works: sleeping bag or sheets/blankets? Is the dinette side a comfortable bed?
Hi, Obviously there is a bunch of personal preference in one's answer. We use sheets and comforter. We don't notice any difference in comfort from either side. But the use of a topper/pad would be highly recommended. The dinette side does have the cushions cut into sections so the dinette can be set up (the other side is single piece). With a mattress topper/pad , you don't feel the split in cushions. We upgraded the seating cushions for the dinette to a much more dense foam. The OEM cushions are a bit soft. We roll up the dinette side daily as we enjoy eating breakfast inside.2025 360 CS
Southern Maryland0 -
We have the dinette side made up on a firm topper cushion, with fitted sheet and blanket. That whole "assembly" gets slid across and sits on top of the other side in the morning. Just takes a minute to convert. We find it very good sleeping. The OEM cushion is decent on the full side.1
Thanks for your input. We are considering using sleeping bags which then can be rolled up and placed behind the dinette seat during the day. But I'm not sure the sleeping bag will be sufficient padding to prevent feeling the split between the cushions.0
We've opted for separate memory foam pads and will also shuffle it over to driver's side if we decide to do the dinette..Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
When I was younger my wife and I used to sleep on the ground. Those days are long gone and I wouldn't even want to sleep on the tab360 cushions with a sleeping bag. We bought 2 30x80 4" foam pads and they are quite comfortable and I can still roll it up and place behind the dinette seat. Normally just leave the beds in place and eat outside unless it is raining0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
