We are about to take delivery of a 2022 Tab 320 BD which has been winterized for travel north. Can we use the Alde system without water in the tank if we just want to heat the trailer for an overnight night stay enroute home? Any special settings or valves to be aware of?
0 ·
Yes, you should be able to use the Alde System for cabin heat. If you are boondocking (no hook ups) you will need to use propane by selecting propane on the Alde panel (the other option is electric). If that is selected you will not have heat without 30 Amp service. It will take some time for the cabin to warm as it is more of a passive heat; but once warmed it will be cozy.
Consider leaving the roof vent and one window cracked open. This will help to minimize condensation forming overnight inside the cabin.
Let us know how your maiden trip goes.
Too much information?
