4Runner brake controller for T@B320
Rick24
Rick24 Member Posts: 17
Does anyone have a recommendation for a good brake controller for a 4Runner towing a T@B320?
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    Hi, We use a Redarc .  Only uses a small control knob...everything else is hidden behind dash.  Very reliable.
    2025 360 CS
    Southern Maryland
  • Horigan
    Horigan Member Posts: 928
    Same here.
    Rich
    2019 T@b 400
    Bellingham WA
  • Freespirit
    Freespirit Member Posts: 187
    I have a Autowbreak controller(and love it) I have used with a 4Runner and a Highlander. Currently using it with my Telluride. The thing I love about this break controller is it attaches to the trailer so changing vehicles is almost seamless.  They are expensive ~$480.00, but in my experience well worth the added cost.
    2020 TAB 320 U
    TV 2025 Telluride X Type
  • Rick24
    Thanks All!
  • Maxcamp
    Maxcamp Member Posts: 352
    edited March 26
    RedDArc on 3rd gen Tacomas have a history of fault in 0F weather, causing faint brake light strobing 24/7 even parked.  May not be issue for you.  Dealt with it two winters now.
  • Maple_Geek
    Maple_Geek Member Posts: 217
    Autowbreak is my go to break controller.Set it and forget it. I can change my tow vehicle and not have to worry about a new break controller. Well worth the look and I strongly recommend it.
    2022 T@B 320S Boondock
    2021 Toyota RAV4 TRD Off Road
    Ottawa, Ontario, Canada
    Instagram: new.t@bventure
  • Rick24
    What setting control setting do you use?
  • Rick24
    Horigan said:
    Same here.
    What controller setting do you use?
  • Rick24
    Rick24 said:
    Horigan said:
    Same here.
    Redarc with a 4Runner and Tab320
  • Horigan
    edited April 2
    Rick24 said:
    Horigan said:
    Same here.
    Generally in the mid-position, but I have a 400.  Each combination will be a bit different as it depends on the weight of the trailer and how well adjusted the trailer brake shoes are.  I would experiment to find the best setting for you, by using the manual control as well as braking at various settings to find where the trailer and the TV brake uniformly, as if the trailer isn't there.
    Rich
    2019 T@b 400
    Bellingham WA
