Battleborn safety issue per Will Prowse?
Is anyone out there following Will Prowse on YouTube about Battleborn battery safety issue of overheating?
I have a 2025 360CS black canyon with standard 100aH Battleborn battery and wondering if this has come up for any nucamp owners?? Thanks!
    It has been discussed in several threads.  I've followed it closely at both his web page and the videos.  It is hard to say how many other owners here are following it "closely".  I know if I had a Battleborn I would be looking very closely at the positive battery terminal to look for discoloration, as described in the videos.
    The problem I have for this issue is the difference in how batteries are charged and discharged in a trailer, compared to the charging and discharging rates someone powering a large solar array for a home, for example.  Do we put that much stress on a battery?  Does having the "large" battery setups with the Multiplus inverters with owners running the AC make a difference?  These are hard questions to answer.
    What is interesting in the various threads is learning how Battleborn has marketing agreements with major manufacturers across the RV industry, including NuCamp.  Which is why the industry heavily promotes the Battleborn brand. Which is fine.  The question will become what happens if Battleborn no longer supports their warranties in the future, or goes bankrupt.
    In any case, a difficult thing to sort through.
    This is one thread:
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    Have you seen the video with the 270Ah battery.  Seems like same if not worse.  That battery is used with lithium package.  Make your own decision.
    2025 360 CS
    Southern Maryland
    qhumberd Administrator, Moderator Posts: 912
    I agree with @pthomas745 that most RV users will not stress a 100Ah Battleborn from a charge and discharge perspective like Prowse's testing shows. What is more of a concern is the lack of build quality and vibration resistance (or not) built into this (or any) battery. So inspecting regularly is certainly prudent for any brand of battery.
    My other concern is how Battleborn is dealing with valid warranty concerns, which is to offer to inspect if the owner ships the battery back at the owner's expense and then make a determination. For such an expensive battery this is pretty much no warranty at all.
  • Idgie
    Idgie Member Posts: 7
    Much appreciation for any and all feedback/thoughts here. I’m a RN not an electrician 😉 The Battleborn response thus far does not appear to be exemplary and once our camper is up and about from winter I will be sure to inspect my battery regularly. Thank All!
  • MOS2
    MOS2 Member Posts: 62
    So what should be inspected on the battleborn?
  • Idgie
    "To address questions that have recently surfaced about terminal heating and fastener design, it is important to highlight that what some observers view as a failure is a safety device working exactly as intended. The aluminum nut used in our 100Ah packs’ positive terminal is a purpose-built thermal failsafe. It is engineered so that the plastic deforms and disconnects when excess heat is present.”
    Might want to check out Will’s video onYouTube as I am absolutely no expert on this!
  • Grumpy_G
    Grumpy_G Member Posts: 788
    This is one of the most hilarious spin attempts ever. Nothing disconnects inside the battery, the nut and bolt merely lose clamping force when the plastic melts. Which makes the problem worse.
  • MOS2
  • jkjenn
    jkjenn Member Posts: 6,425
  • Grumpy_G
    Maybe Dragonfly should have checked with DCS in Australia how effective lawsuits are …. :)
    It's also ironic that the lawsuit claims Will Prowse modified the batteries while in the interview Denis Phares stated "The most stringent electrical test requires the battery to survive a short circuit where the primary protection mechanism is faulted. In our case, this amounted to completely bypassing the Battery Management System (BMS)". So it's ok to modify the battery for safety testing or not ?
  • jkjenn
    I don't pretend to understand electricity at the level these guys are debating, but this part from Dragonfly rang true to me:
    "In high-current DC systems like RV and off-grid applications, heat at or near battery terminals is almost always related to resistance in the external electrical system, not an internal battery issue.
    Common causes include loose connections, improper torque, undersized wiring, or resistance elsewhere in the system such as bus bars, disconnects, or inverter connections. When current flows through a high-resistance point, it generates heat.
    Heat can also travel along conductors, so it may appear to originate at the battery even when the source is elsewhere in the system."
    There are always two sides to every story and I am glad to hear Dragonfly's side.
    I was disappointed that the interview did not address the specific issues that Will Prowse documented on his video where he bought a new intact 100aH BB battery and tested it according to the specs sheet and the battery failed. Only then was the battery cut open. That battery was not attached to an RV, only to a cycle machine that measures discharge and charge cycles. And the battery failed.
    So they sued him instead of responding to the issues he raised, saying all the problems as far as they know were due to user mistakes.
    100aH BB test
  • rydfree
    rydfree Member Posts: 44
    Has anyone here in the RV applications ever experienced any issues with the Battle Born batteries or is everyone just getting overly concerned with the video of a YouTube influencer ? You can pick most any product and find influencers that either hate it or love it.
  • jkjenn
    I have never heard of a single issue from a nuCamp owner.
    @jkjenn Agreed. We have not had a forum thread for BB battery concerns or failures. In fact I don’t recall reports for ANY brand of Lithium battery OEM or DIY failures. As opposed to, say Alde corrosion, which is literally years in length.
  • Yoshi_TAB
    edited June 3
    I am not making any judgement on the validity of the failure mechanism point out by Mr. Prowse.
    But in the world of engineering failure hazard analysis, just because it has not happened, absolutely does not indicate the failure cannot happen or is not "lurking" sometime to happen. There are often some "not possible" failure scenarios in a system (maybe this is one of them), but probably not likely. Almost nothing is fool proof, even with double and triple redundancy.
    When a chemical system is designed, all failure scenarios for all components are evaluated, from the most expected failure to the least likely.
    To put the community at rest or say it cannot happen, BB should provide hard data for the root cause failure (by an independent group of engineers or scientists) of every component in the "battery "system" There are many types of hazard analysis and I'm sure if this ends up in the legal system, BB will be required to provide one.
    2025 360 CS
    Southern Maryland
  • rydfree
    If you approach any issue with the expectations of finding a problem, you probably will. From what I've read, this seems like a lot of paranoia and fear mongering. Nobody has had a problem, But But What if !!!
  • Yoshi_TAB
    edited June 3
    "If you approach any issue with the expectations of finding a problem, you probably will"
    Correct…that is the point and the exact reason hazard analysis shall be conducted on any system that could potentially harm people, equipment or facilities. It is OSHA/CFR law that it be done. Manufacturers have no choice if they perform manufacturing. How well they are done is another question. Accidents do happen, but the purpose is to look ahead and put mitigations in place when potential hazards are identified for both the end user of the product and those who manufacturer the product. There is a lot of good that comes from them, including operator safety and final product user safety. HAs also often identify engineering design flaws.
    2025 360 CS
    Southern Maryland
  • rydfree
    "…..if you have a large battery setup from Battleborn, or any Battleborn, for that matter, you should inspect the battery for the discoloration of the positive terminal that indicates the overheating problem. This is the message a Battleborn owner should take from this controversy."
    As everyone should be doing with any potentially hazardous system, be it lithium, lead acid battery or propane etc.
    You need to routinely check condition and note any irregularities.
    I had a popular well reviewed Amazon solar charge controller decide one day to just keep charging my lead acid battery on my pond aerator until it exploded. It destroyed the enclosure it was in and sounded like a shotgun blast from the house 1000' away up the hill. I would have hated for that thing to have been in a small camper . $..t happens.
  • jkjenn
    edited June 5
    If you are interested, Mike Sokol, who I have followed for years, has been conducting thorough testing in the BB batteries and posting about it on his Substack since April. He is very detailed about his methods and replies to comments and questions about his approach. To date, he has not been able to replicate the failure. He just ordered a vibration table to try to replicate RV movement.
    Mike Sokol Blog
    EEdit To add link: Archive - RVelectricity https://share.google/C4WPiJQF6e0NIFgj3
  • rydfree
    Thought I would revisit this thread and see if anyone here has used these stick-on fire extinguishers. I think I will put a couple in the wheel well with the two Battleborn 100ah batteries.
    FEROSTICKER - The world's smallest automatic fire extinguisher
  • Dasieg
    Dasieg Member Posts: 23
    I had a 100ah Battle born in my tab 400 for four years. No problems at all other than the fact that it could not handle more than one or two days of boondocking without being depleted (despite solar). It always recharged promptly and fully however. I replaced it with a 230 ah Litime just now. The battle born terminals were pristine and charged to full voltage when pulled.
  • elbolillo
    elbolillo Member Posts: 575
    For what it is worth, I have a 400ah BB bank in my Tab 400. As of yet I have not run into any issues. I regularly check all my connections and have measured the temp of the battery posts and everything is normal and running great.
  • Okpete
    Okpete Member Posts: 44
    Will Prowse does not have credentials. Not associated with with any recognized testing facilities. I go to various meetups and read most Nucamp forums. I have not heard or seen anyone having a BB failure. Certainly overpriced
  • rydfree
    I agree, no issues here with my 2 Battleborn batteries. I just think a non-toxic fire suppression system would be prudent in any brand battery system. I'll probably put one in the compartment with the Victron charger/ inverter also.
    We have been around and around with the Will Prowse- Battleborn issue. If you don't believe there have been any "reported failures", you haven't looked closely enough at the several testing videos he has done, and the dozens of Battleborn owners who have reported and documented failures of the Battleborn. Of course, we probably have not had any failures in any of the NuCamp products, but claiming the issue does not exist and should not be watched for is the wrong approach.
    We have seen plenty of owners reporting "my battery just shut down", everything possible is examined to discover the issue, and then…like magic, the battery comes back to life. Is this the plastic "safety mechanism" in action? Impossible to tell, unless you know exactly what to look for.
    The RV industry as a whole is desperate to support Battleborn, because when they go out of business, and all the owners warranty promises disappear, it will all come right back to the manufacturers.
    This is the clear difference between anecdote and science, which is getting a pretty bad rap of late. Reminds me of the film "Don't Look Up".
    I for one am waiting for more testing with Mike Sokol, who is doing what science would call "replication" studies. But I am also quite concerned with what I have seen so far.
    Also, I am curious, @rydfree about the fire suppression system stopping a fire that is not a typical combustion but driven by a lithium battery cell failure creating a whole lot of heat.
  • rydfree
    From the Will Prowse video it looked more like the plastic case was fueling the fire and it took quite a while. I'm not convinced we would see that type of an issue but the fire suppression should keep the other combustibles from going up quickly and give adequate time to react if you are inside the RV when it happened. I am going to be moving my two Battleborn batteries to my solar pond aerator setup and replacing with 300ah setup in the RV anyway. Better to be safe than sorry just in case. I will be putting a couple of the fire suppression sticks in the solar pond aerator setup as well since it resides in a gazebo on the pond island. They may put the fire out or not if one ever does occur. I may test one of those sticks by purposely starting a lithium fire in an enclosure with a couple of my old large RC LiPo batteries. Lipo is much more difficult of a fire than the cells used in our batteries so it would be interesting.
  • ginsbuj
    ginsbuj Member Posts: 58
    Battleborn in a 2019 Tab 320 worked great for 5 years. Once I even depleted it and it shut off as intended and I had to restart with a jump start without issues. I have 2 in my 360 and they are great. These influences are becoming way too powerful on the Internet.
    TAB 360 Black Canyon
