Isolating a non lithium compatible WFCO converter when upgrading to lithium
I don't use AI often but here is what it (in summary) told me to do:
Strong Recommendation:
It is highly recommended to isolate the WFCO converter from the lithium battery when you are using your dedicated 10A lithium charger, or when the RV is on shore power in general.
As mentioned in the previous response, you can do this by:
Installing a battery disconnect switch between the WFCO's output and the battery.
Turning off the breaker or pulling the fuse for the WFCO converter's output when on shore power.
This ensures that only your LiFePO4-compatible charger is interacting with the battery when you want it charged, maximizing its performance and lifespan.
So here is my human question:
1. I have the WFCO 8955 PEC (non lithium compatible).
2. I just swapped out my Harris AGMs for a single 230 amp hour LiTime battery. I got a 10 amp Litime charger to bring the battery to full charge when needed.
3. I have a Renogy suitcase 100W solar setup with controller that does have a lithium fe phosphate setting, but when in storage I can't use this.
4. I have a basic shunt installed that can monitor the battery SOC.
Based upon all these recommendations, can I just disconnect the WFCO charging function by disconnecting the wires to the battery at the converter board and not do anything else?
Thanks all
Well I may have answered my own question. When looking at the WFCO circuit, there are two lugs/ wires that are marked “to battery”.
But disconnecting them seems to block the WFCO from supplying 12V to the trailer circuits when on shore power. So I can seem to figure out how to disable the battery charge part of WFCO without also stopping 12V power to the trailer circuits.
The WFCO manual states it will work with no battery installed, so what did I miss?2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
So it requires not forgetting to turn off the battery switch whenever you connect to shore power, but because the WFCO is an integrated circuit it connect on its circuit board disconnect from the battery charging without losing the 12V service to the trailer.
This is how my AI summarized, and it looks reasonable if you don't want to charge your lithium battery with the non lithium WFCO:
>>>>>>>>>>>>>>>>>>>>>>>Excellent! Having a battery disconnect in place makes this much simpler and safer. You are on the right track.
Let's confirm the steps for using your existing battery disconnect switch to prevent the WFCO-8955PEC from charging your battery, while still allowing the battery to power your RV when off shore power:
Goal:
Prevent WFCO-8955PEC from charging the battery when on shore power.
Allow the battery to power 12V circuits when off shore power.
Allow the WFCO-8955PEC to power 12V circuits when on shore power (even if the battery is disconnected).
Steps:
When connected to Shore Power and you DO NOT want the battery to charge:
Engage your existing Battery Disconnect Switch to the "OFF" or "DISCONNECT" position.
Result: This physically or electrically isolates your RV battery from the rest of the 12V DC system, including the WFCO converter.
Outcome 1 (Charging): Since the battery is disconnected, the WFCO converter will not be able to send charging current to the battery.
Outcome 2 (12V Power): The WFCO converter, when plugged into shore power, will still continue to supply 12V DC power to all your RV's 12V circuits (lights, fans, etc.). The RV will operate normally on 12V power, but that power will be coming directly from the WFCO converter, not the battery.
Outcome 3 (Battery): Your battery's state of charge will not change, as it's isolated. If you have a separate, external battery charger you wish to use, you can connect it directly to the battery terminals when the battery is disconnected from the RV.
When NOT connected to Shore Power and you want the battery to supply 12V power:
Engage your existing Battery Disconnect Switch to the "ON" or "CONNECT" position.
Result: This connects your RV battery to the rest of the 12V DC system.
Outcome: Your battery will now be the sole source of 12V DC power for all your RV's 12V circuits. The WFCO converter will be idle (as it has no AC input), and all 12V loads will draw from the battery.
Important Confirmation & Verification:
Understand your specific switch: Some battery disconnect switches cut the positive cable, others the negative. For your purpose, either works as long as it truly isolates the battery from the RV's main DC bus.
Verify Isolation (Optional but Recommended):
Plug your RV into shore power.
Turn your battery disconnect switch to "OFF."
Using a multimeter, carefully measure the voltage directly across your battery terminals. It should show the battery's voltage (e.g., 12.6V).
Then, measure the voltage on the RV side of the disconnect switch (i.e., the cable coming from the switch towards the WFCO). With the switch off, this cable should not show the converter's output voltage (e.g., 13.6V or higher). If it does, your switch might not be fully isolating the battery.
Finally, turn on a 12V light inside your RV. It should illuminate, confirming the WFCO is still supplying power to the circuits.
This approach is exactly what a battery disconnect switch is designed for in this kind of scenario. It's safe, effective, and uses existing equipment.
We rarely have shore power while camping, but when we do I'll simply turn the battery disconnect off. In our case, rooftop solar will keep the battery topped off, but with the switch off there is very little discharge on the LiFePO4's. I have mounted a 30amp charger near the battery. It's wired directly to the battery and bypasses the battery disconnect. When there's a need to charge from shore power while the battery switch is off I'll use that, but it seldom happens.
Great, that sounds like it will work for me as well.
thanks for your help2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
When I put the Converter in my Tab 320 on its own breaker, I also mounted a 120 Volt receptacle next to the WFCO panel. The receptacle is powered from the Converter breaker, using 14/2 Romex. I cut off the female end of a 15 Amp (14 AWG stranded wire) extension cord and permanently wired it to the Converter. The Converter now draws its power from the newly installed 120V receptacle. The receptacle allows me to also plug in our Ecoflow Delta 3 Plus for charging, or plug in our 60A LiTime charger when I eventually install the 300AH Newtipower lithium battery. It also makes it easy to disconnect the Converter-just unplug it from the receptacle.
2021 Tab 320S Boondock. 2016 Toyota Tundra TV.
Sabattus, ME & eventually Tucson, AZ0 -
If connecting an Li charger “directly” to the battery, be sure to connect the negative charging wire to the Load side of the shunt.When I added a solar charger and an Li charger, I replaced the one stud terminal block with a multi-stud bus bar so as not to stack terminals on a stud.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA3 -
Yep thanks. As usual I forgot a step. Now it all works for my setup. Travel with battery on, powering frig and emergency brakes. The small charge fro TV alternator not an issue.
Camp ⛺️ on battery as required, and then when at a site with shore power or back home make sue battery disconnected, then plug in small charger. Shunt tracks use and recharge.
We are ready.
best to all2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
You don't need to disconnect the converter to use a stand alone charger. Your solar is connected directly to the battery and charges whether or not you have the WFCO on shore power.
Your non-Lithium modified WFCO won't output high enough voltage to fully charge your new battery. Your solar can when there's enough sun, and your smart stand alone charger can. The battery management system in your battery cuts off charging once it reaches capacity no matter how many charge sources you have coming in.
Note that even when you turn off the battery disconnect switch, the solar input goes directly to the battery. The solar controller and smart shunt both will consume power from the battery to run their bluetooth radios. I also have a TPMS amplifier that's connected directly to our battery. The disconnect just isolates the battery from the converter and the DC circuits that are fused at your converter.Utah-based
2023 T@B 320 S Boondock2 -
@qhumberd I'm not sure how you are connecting your LiTime battery charger to charge your batteries, but an easy way is to plug it into the solar port. I've done with this my Noco 10amp charger. You'll need to get adapters for the correct polarity. The WFCO in my '23 400 wasn't charging the lithium correctly so just as you said above, if at camp with hook-ups, I could use the 20amp outlet at the pedestal for the charger while the trailer is plugged into the 30 amp, turn off the battery and plug into the solar port. I've also done this at home during winter storage, and, I've done this while camping without hookups and plugging into my Goal Zero 1000watt battery bank.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0 -
Thanks @bjn2 and @dsfdogs for that feedback. I perhaps was being overly cautious with this new and relatively expensive battery. Not having extensive electrical experience I was not sure that keeping the lithium battery on the non lithium WFCO while also on my smaller 10 am lithium charger was safe for the battery. But I guess that electrons are electrons no matter where they are generated, and the BMS on the new battery is there to protect it.
I have room and a 120 V plug in my cargo bay set up for the small charger, so I should not need to use the solar port, but it is great to know that is an option. I just tried this out by discharging the new battery off shore power to around 50 % then disconnecting the battery and plugging the trailer to shore power and plugging in the small 10 amp charger. It was slow, but it worked fine. Running both together would be a lot faster, as long as it is safe for the battery.2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
I've never charged with the Noco battery charger and the WFCO at the same time. I guess I'm cautious too.Debbie in Oregon
Sold 2023 Tab 400
If I'm plugged into shore power the batteries are off. I just put a disconnect switch right after the battery shunt and have a Victron Smart charger that plugs into shore power wired in after the shunt to charge the batteries. The Victron smart charger supplies 30 amps so the batteries charge quickly. I wouldn't depend on a WFCO auto sensing converter for charging any lithium.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
If there is no hurry, then charging with converter isolated just seems reasonable.dsfdogs said:I've never charged with the Noco battery charger and the WFCO at the same time. I guess I'm cautious too.
And @SLJ I put my charger on the load side of my shunt so I could keep up with charge going to the battery and time left to 100%. Otherwise my process is just like yours. Likely your shunt is able to figure out your battery SOC; mine has to be reset unless it goes thru the shunt2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
This thread is super informative. I just bought a Victron IP 65 charger to properly charge my lithium battery because the WFCO auto detect is not sufficient. It took 3 tries to get the IP 65 to properly charge the battery. First time it spiked to 14.2 volts and dropped like a brick. Second time the IP 65 showed it was charging at 14.2 volts for 30 minutes - but Smart Shunt showed voltage was actually 13.7. I read that the IP 65 can be off by about 5 v. Third try I set the IP 65 at 14.7 and it charged at 14.4 for 30 minutes. Yay! All three times I was plugged into shore power at our house. First time - battery switch was on and WFCO was on - green light - which I thought meant that it interfered with the IP 65 and caused the voltage to drop. Second time - WFCO was off - battery disconnect was off. I thought this did the trick and charged stayed at 14.2 but I was wrong. Third time - battery disconnect off, plugged into house, WFCO was on - yet I was able to bypass the WFCO and charge to 14.4 for 30 minutes. I have no idea why the WFCO stayed on the third time but not the second. I guess I will just let it go - since I did accomplish my goal of charging to 14.4 for 30 minutes.
As mentioned earlier, I have a Victron IP22 30amp charger mounted in our tub close to the batteries and wired directly to them. When charging using the IP22, I now always turn the battery switch off to prevent the WFCO from also charging. In the past when having both the WFCO and IP22 charging I did not get a full charge. My thought is that the voltage coming from the WFCO is seen by the IP22 as the level of charge in the battery, so it come out of bulk mode too soon. With both the WFCO and IP22 charging there are initially more amps being fed into the batteries, but the IP22 goes into absorption or float too soon. Thoughts?
That sounds right to me. I did read that the IP 22 doesn't have the 5 volt variation that the IP 65 has - so that's good. I'm still stumped as to why I was able to properly charge with the WFCO on last night - maybe it was because I had the IP 65 set to 14.7 absorption charge - well beyond the WFCO ability to charge. I'll pay more attention to any other variables next time I top off the battery. I did use a different outlet in the camper to plug in the IP 65 but that probably shouldn't matter. It's just strange - one time nothing is on when battery disconnect is off which made sense to me - next time everything works despite having battery disconnect off. I'll eventually figure that out but for now I'm just leaving things alone for the winter.1
I don't even let the newer "auto detect" WFCO charge my Lithiums.2021 T@B 320 S Boondock
2025 Ford Ranger
The Finger Lakes of New York1 -
Have 100ah lithium with non-lithium WFCO converter and never shut off battery. 5 yrs and 65k miles and never a problem. If need that extra 15% just always used our portable solar panel to top it off. But we usually camp at places with shore power. But now we are doing more camping without shore power like Harvest Hosts. Recently installed a Bluetti Chargeer 1 alternator charger and use it conjunction with my standalone Victron 100-20 Solar Controller (my 2018 320 doesn't have rooftop solar). Get a steady 290 plus watts just driving down the road so tops of battery pretty quick and alway arrive at campground at 100%. If boondocking and solar is iffy can just hook up to truck for a bit and charges right up. Plus, since output voltage can be set manually, when I'm unhooked and going somewhere with just the truck can connect to my solar battery and charge it up quickly too. Different ways to get there I suppose.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"1 -
rcarlson1957 ... alternator charger is a great idea! I love the idea of charging while driving ... would keep the refrigerator cold on days when I'm driving four hours or so. Also, I will be camping for three nights this summer at a campground with no electric and lots of trees. The Bluetti would solve that problem - I could add some life to the battery with the vehicle. Also, that means I wouldn't have to buy a generator for situations where solar isn't enough.0
When I'm plugged into shore power I have a switch and shut off the batteries. Camper 12 volts is supplied by the WFCO. The batteries are then charged by a Victron 30A smart charger. When I unplug from shore power the batteries are switched back on.2021 T@B 320 S Boondock
2025 Ford Ranger
I just read through all your modifications. Amazing. Thanks for your response. I'm not sure whether my WFCO was interfering with charging my lithium - but I managed to get it charged at the proper profile so I guess all is well. I'm so envious of people who have the skills and confidence to do all the mods you have done. Bravo.SLJ said:When I'm plugged into shore power I have a switch and shut off the batteries. Camper 12 volts is supplied by the WFCO. The batteries are then charged by a Victron 30A smart charger. When I unplug from shore power the batteries are switched back on.0 -
On our build - 2024 400 . We installed 900Ah of lithium batteries and a 3000w Renogy inverter / charger . Since the new 3000w inverter is charging our lithium batteries , we isolated the standard WFCO converter charger to its own breaker on the WFCO breaker panel .
BTW, We had no issues with the stock WFCO charging our lithium batteries . The auto detect feature worked just fine .
Our 3000w inverter / charger is charging our batteries at 75 amps , if we turn on the stock WFCO charger , along with the inverter charger , we can charge up to 130 amps if needed . Also , its good redundancy , that we have the stock WFCO 55 amp charger incase the inverter charger stops working . Usually we leave the stock WFCO charger breaker off , and let the inverter charger do its thing since we can customize the battery charge parameters unlike the stock WFCO charger . So for shore power charging we have either 75amps(inverter charger) , 55amps (stock WFCO) , or both at 130amps . Also have 620w of solar on the roof .
The stock breaker box setup has the converter , 1200w inverter and rear cubbies on the same breaker . We removed the stock 1200w inverter completely when we installed the 3000w inline inverter . The rear cubbies feed , we moved to another breaker in the breaker box . In essence just leaving the converter breaker by itself that we can turn on or off at will . Usually we just leave it off.
2019 NuCamp T@B 320s Grey / Black - SOLD3 -
@rcarlson1957rcarlson1957 said:...Recently installed a Bluetti Chargeer 1 alternator charger ...
Curious. The Bluetti Charger 1 is rated for 580W. Do you know if you're only getting 200W because that's all the Honda alternator will put out, or due to small gauge wiring to the trailer battery (580W would call for 6AWG), or a combination of both? I've wondered if modern smart alternators would put out 500W (40+ amps) and whether it would be worth running 6 or 8 AWG wire thru the TV and to the trailer battery.Rich2019 T@b 400
Horigan - Sorry I posted incorrectly and fixed it my original post. The Charger 1 can output up to 580w at 10 amps when you set it's output voltage to the max of 58v. One of things I like about it is that you can manually set the output voltage via their phone app. But my Victron 100/20 solar controller can only handle a max of 290w on it's 12v setting so it. So I set the Charger 1 output voltage to 28v and it limits is to that max wattage. I also have a Bluetti EB3A solar battery that takes a 28v input too. So I keep the Charger 1 set at 28v so I don't have to change it's output voltage setting when I switch between charging my 100ah lithium camper battery or my solar battery. With the Charger 1 it is very important you always have the correct output voltage set to the correct input voltage for your solar battery before you hook it up or you can damage the solar battery. By setting my Charger 1 to 28v I don't have to worry about that. If I got a bigger solar battery then I would have to take that into account each time I switched. The Bluetti Charger 1 normally comes with some nice 6awg wire with a wire mesh protector that is just under 16.5 feet long with a switchable breaker on the Charger 1 input end. I installed a separate breaker 60amp breaker with manual reset by my truck battery. I installed the Charger 1 on inside drivers side of my Ridgeline truck bed (it's under a tonneau cover). I was able to run it thru the inside front fender well into truck cab and under the front and back seat sill plates and then behind the rear seat and out into the truck bed. I've been using it for quite awhile now with no problems. But since my truck has a smart alternator I do have to run the truck with the lights on for it to work properly. Here's a picture of the Charger 1 when it's running and charging my camper battery.
2018 TAB 320S
North Texas
"Our favorite trip will always be our next one"0 -
Thanks @rcarlson1957 for the detailed explanation. Makes sense for your setup.
Rich2019 T@b 400
Not sure why you would. My 2018 has had a non lithium attached to 100ah lifepo4 for over 5 years. Solar gets the volts up to max charge of 14.6 enough that I don’t have balance issues in service. We are not full time but have done 2-4 weeks many times. I don’t know why people worry about changing things unless they prove deficient in practice.
2 -
@Spectre9 is correct. I ran the stock charger on our 2020 for a long while with 200ah of lifepo4. I reconfigured the Victron solar charge controller for lithium which would fully charge the batteries. Our camping trips were typically 2-3 nights in length so we were mostly boondocking but when we did plug in shore power it didn't harm anything. This setup would only have been an issue if a travel/camping itinerary were dependent upon topping off the batteries from shore power.
I eventually changed out the WFCO controller for the lithium-compatible model just in case, but I can't recall a single instance where it made a bit of difference.1 -
As long as you have plenty of sun or don't need to charge to 100% it won't make a difference. Makes a difference for us as we boondock and like to park in the shade with no hook-ups for days at a time. I don't even depend on the auto-detect WFCO in our newer camper. Too long a history of problems with them. I installed a Victron 30A Smart Charger in that also.dutsmiller said:I eventually changed out the WFCO controller for the lithium-compatible model just in case, but I can't recall a single instance where it made a bit of difference.
2025 Ford Ranger
I isolated my WFCO even though it was supposedly Lithium compatible. Never got it to charge properly.If interested, scroll down to my postings in the following discussion:I installed a Victron Blue Smart Charger along with a relay that switches the charging circuit from the WFCO to the Victron when plugged into shore power.If you use the Victron networking and have a Victron Smart Shunt the charger will boost the output voltage to compensate for the voltage drop so no need to upgrade the wire to the battery - 10 ga is just fine. Just setup the Victron charger for Lithium charging and it all works great.
2022 T@B 320S Boondock1
